Stefanho Posted February 27, 2005 Posted February 27, 2005 Hello,i've got the following question:What is the best solution to scale the controller resolution from 0-127 to 0-100?I think this should be no problem. ??Greetings,Stefan
TK. Posted February 27, 2005 Posted February 27, 2005 Hi Stefan,here an excerpt from the midibox64 application:;; --------------------------------------------------------------------------;; This function scales a 7bit value depending on a min and max value;; If the min value is greater than the max value, they will be;; automatically converted to realise a reversed scaling;; Input:;; o 7bit value in WREG;; o min value in MB64_POT_MIN_VALUE;; o max value in MB64_POT_MAX_VALUE;; Output:;; o scaled value in WREG and MIOS_PARAMETER1;; USES: MIOS_PARAMETER1 and MIOS_PARAMETER2;; --------------------------------------------------------------------------MB64_POT_ScaleValue ;; save pot value in MIOS_PARAMETER1 movwf MIOS_PARAMETER1 SET_BSR MB64_BASE ;; send min value if min == max movf MB64_POT_MIN_VALUE, W, BANKED IFNEQ MB64_POT_MAX_VALUE, BANKED, rgoto MB64_POT_ScaleValueDo movwf MIOS_PARAMETER1 rgoto MB64_POT_ScaleValue_EndMB64_POT_ScaleValueDo ;; set MIOS_PARAMETER2[0] if min > max bcf MIOS_PARAMETER2, 0 movf MB64_POT_MAX_VALUE, W, BANKED IFLEQ MB64_POT_MIN_VALUE, BANKED, rgoto MB64_POT_ScaleValue_NoConv bsf MIOS_PARAMETER2, 0MB64_POT_ScaleValue_NoConv ;; scaled value-1 = ((current value+1) * (max-min+1)) / 128 ;; swap max/min if MIOS_PARAMETER2[0] set ;; multiply current value * (max-min+1) IFSET MIOS_PARAMETER2, 0, rgoto MB64_POT_ScaleValue_InvMB64_POT_ScaleValue_NoInv movf MB64_POT_MIN_VALUE, W, BANKED subwf MB64_POT_MAX_VALUE, W, BANKED rgoto MB64_POT_ScaleValue_Cont1MB64_POT_ScaleValue_Inv movf MB64_POT_MAX_VALUE, W, BANKED subwf MB64_POT_MIN_VALUE, W, BANKED ;; rgoto MB64_POT_ScaleValue_Cont1MB64_POT_ScaleValue_Cont1 addlw 1 mulwf MIOS_PARAMETER1, ACCESS ; multiply with current value ;; divide result by 128 (result >> 7) ;; good trick: just shift the upper bit of the low byte into the high byte rlf PRODL, W rlf PRODH, W andlw 0x7f ;; add min or max value depending on MIOS_PARAMETER2[0] btfss MIOS_PARAMETER2, 0 addwf MB64_POT_MIN_VALUE, W, BANKED btfsc MIOS_PARAMETER2, 0 addwf MB64_POT_MAX_VALUE, W, BANKED ;; store result in MIOS_PARAMETER1 movwf MIOS_PARAMETER1MB64_POT_ScaleValue_End movf MIOS_PARAMETER1, W ;; return immediately if inversion bit not set IFCLR MIOS_PARAMETER2, 0, return ;; else inverse the result subwf MB64_POT_MIN_VALUE, W, BANKED addwf MB64_POT_MAX_VALUE, W, BANKED movwf MIOS_PARAMETER1 return[/code]Note: MB64_BASE is the base pointer to the page where MB64_POT_MIN_VALUE and MB64_POT_MAX_VALUE are located.Best Regards, Thorsten.
Stefanho Posted February 28, 2005 Author Posted February 28, 2005 Hi,great news! Thank you! ;D I tested it with an encoder. Worked very well.Next step are motorfaders. Cheers,Stefan
Stefanho Posted March 2, 2005 Author Posted March 2, 2005 Hello again,i've tested it with my motorfaders. If i move a fader it works as expected.But when i send a controller-message the fader jumps to the non scaled position (values 0..127). I use the Midibox64e application. I think, i have to modify "MB64E_FADER_Move" from "mb64e_fader.inc" ?The values, which are send to the midibox, range from 0..100.Regards,Stefan
TK. Posted March 2, 2005 Posted March 2, 2005 Hi Stefan,yes, you have to scale back the value from 0-100 to 0-127Best Regards, Thorsten.
