Davo Posted April 6, 2005 Report Posted April 6, 2005 I'm thinking of putting a simple mixer in what will become my SID and FM synths so I can simply plug in an amp and go. This circuit: http://www.musicfromouterspace.com/analogsynth/monomixerpage.html seems appropriate. Comments? Quote
arumblack Posted April 6, 2005 Report Posted April 6, 2005 A textbook summing amp with a headphone amp added in for kick's. Should do the trick. Quote
MMorph Posted April 6, 2005 Report Posted April 6, 2005 Well, while it's not being the most elegant way to design a mixer, it will definitely work! I used to have similar gadget built in early 90's for my personal use. You just need to have a dual-voltage supply to power up the thing. For the record, Tomi Engdahl's page lists several other mixer designs as well at: http://www.epanorama.net/links/audiocircuits.html#mixerRegards, Petri Quote
Davo Posted April 6, 2005 Author Report Posted April 6, 2005 The object is not elegance, but simply a mono output. Sometime later I'd like to make a simple 1U mixer specifically for synth use. That link looks like a very good place to start.Thanks! Quote
