putting a mono-out jack on SID and FM synths.
Well, while it's not being the most elegant way to design a mixer, it will definitely work! I used to have similar gadget built in early 90's for my personal use. You just need to have a dual-voltage supply to power up the thing. For the record, Tomi Engdahl's page lists several other mixer designs as well at: http://www.epanorama.net/links/audiocircuits.html#mixer
Regards, Petri
The object is not elegance, but simply a mono output.  Sometime later I'd like to make a simple 1U mixer specifically for synth use.  That link looks like a very good place to start.
Thanks!
