shaduz Posted January 14, 2003 Posted January 14, 2003 Hi all,anyone knows if it's possible to use 2 of the midiboxPlus buttons as "Program Change UP" and "Program Change DOWN"? I can assign a known program number to a button, but it would be more useful to increase/decrease the current patch number with only 2 buttons... hope some1 can help ;DGreetings [shaduz]
TK. Posted January 16, 2003 Posted January 16, 2003 Yes, thats possible with the example Meta event which is already included in v1.909:;; this example sends a registered value, it allows you to increment/decrement a program change: ;; first value: Fn - n stands for the selected MIDI channel ;; second value: if 00: decrement, 01: increment, 02: send without increment/decrement ;; third value: decrement/increment: don't care; else the value which should be sent and stored into the internal register ;; necessary definitions in midibox16.ini: ;; 1.1 = F0 00 7F @OnOff ;; 1.2 = F0 01 7F @OnOff ;; 1.3 = F0 02 7F @OnOff
shaduz Posted January 17, 2003 Author Posted January 17, 2003 Thanks so much Thorsten !!! You always have a good answer... ;)Greetings[shaduz]
