Metrophage Posted May 17, 2005 Report Share Posted May 17, 2005 Reading the main SEQ page, I see that the clock divisions are all even. Is it a straightforward thing to change them in the firmware code, so I could get odd number divisions and primes? I don't usually do even-meter stuff, so I am usually stuck doing this by computer, or with lots of analog modules. I'd love to tweak the clock divisions live to my MIDI gear with something like this. Is it just something like changing an "X/16" to something else, like "X/11", or is it more involved? This is my first PIC experience, so I don't know how such stuff works exactly.M Quote Link to comment Share on other sites More sharing options...
moxi Posted May 18, 2005 Report Share Posted May 18, 2005 hi ,you can set the number of step for each track (e.g. track 1= 16 steps ; track 2 = any number from 1 to 16 ;) Quote Link to comment Share on other sites More sharing options...
Metrophage Posted May 18, 2005 Author Report Share Posted May 18, 2005 Hi Moxi,Yes, setting step length is definately something to be happy about. Also I am wondering about setting the tempo of each track. Sounds like it is time for me to learn more about the MIDIbox firmware, and try it out for myself!CJ Quote Link to comment Share on other sites More sharing options...
moxi Posted May 18, 2005 Report Share Posted May 18, 2005 it's a "track divide" parameter on the seq : bpm ;bpm/2 ;bpm/4 ....to 64 ,it's really helpfull ; but no separate bpm by track.. Quote Link to comment Share on other sites More sharing options...
TK. Posted May 18, 2005 Report Share Posted May 18, 2005 Independent BPM rates would require dedicated hardware timers for each track --- this is not possible, all timers of the PIC are allocated.But you could customize the BPM divider if you want. Currently only even numbers are provided, since they can be easily derived from a bitmask.I haven't taken odd numbers into account, but there is only one place in the sequencer core which needs to be changed:SEQ_CORE_Clk_NextStep_No1st ;; increment SEQ_TRKSTEPx and save new value in TMP1 movlw SEQ_TRKSTEPx incf PLUSW0, F movff PLUSW0, TMP1 ;; check for max value which depends on divider setting movlw SEQ_TRKDIVLENx movf PLUSW0, W ;; 0->1, 1->2, 2->4, 3->8, 4->16... hey, thats simply the output of MIOS_HLP_GetBitORMask call MIOS_HLP_GetBitORMask[/code]so, if you would call an own jumptable function instead of MIOS_HLP_GetBitORMask, you could realize any divider.up to 16 different divider settings are possible, this means that for the case BPM/1 ... BPM/16 you could just replace "call MIOS_HLP_GetBitORMask" by "andlw 0x0f" and "addlw 1", this will work without changing the data structuresBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Metrophage Posted May 18, 2005 Author Report Share Posted May 18, 2005 This is really excellent to hear! I was guessing that completely separate tempo would require multiple sequencers (not such a bad thing!). Indeed, it was more varied clock divisions which I was thinking of. I am delighted to read that this can be implemented relatively easily! This more or less cinches that I will try to start making on of these projects soon! Thanks so much Thorsten!M Quote Link to comment Share on other sites More sharing options...
moxi Posted May 18, 2005 Report Share Posted May 18, 2005 hi thorsten ,that a great things ,especially to play with "ternary tempo" : with such a thing ,you can do ternary pattern without the help of the alternative gate mode!!! Quote Link to comment Share on other sites More sharing options...
TK. Posted May 21, 2005 Report Share Posted May 21, 2005 I think I will change this in the next official release, because it really allows more variations than the current BPM divider settings.This would mean that BPM/32 and BPM/64 won't be available anymore. However, if somebody needs this (I don't think so), then he is always allowed to reverse the change ;-)Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
cheater Posted May 24, 2005 Report Share Posted May 24, 2005 Too bad you can't control this in real time... :( Quote Link to comment Share on other sites More sharing options...
TK. Posted May 24, 2005 Report Share Posted May 24, 2005 What cannot be controlled in realtime?Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Metrophage Posted May 26, 2005 Author Report Share Posted May 26, 2005 Cheater - we are talking about sequencing in real time, with software VS dedicated hardware. On a lot of gear and software, complex rhythmic tweaks aren't available in real time, if at all. But there are some, it just takes creative people to make it. I have a lot of software, now I am looking for real time hardware sequencer for MIDI and CV. That's why I am here!CJ Quote Link to comment Share on other sites More sharing options...
cheater Posted June 10, 2005 Report Share Posted June 10, 2005 Oh, I'm sorry, I missed your reply the first time around.I also should have been more clear.What I was talking about is setting an arbitrary BPM divider while the unit is working. Quote Link to comment Share on other sites More sharing options...
TK. Posted July 3, 2005 Report Share Posted July 3, 2005 The change is now available in v2.3Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
