k-rite Posted May 19, 2005 Posted May 19, 2005 Hello there, I'm a newbie to midibox. I've been looking at all types of documentation trying to understand how to power 1 MBHP Core & 1 SID. I'm trying to do just the very basic setup to learn a bit.The way I understand it is, I can take 5Vdc from the C64 PSU to J1 on the Core and 12Vac from the C64 PSU to J1 of the SID and both circuits will be powered? Do I have to connect power to anywhere else? I was looking at the schmetic of "how to connect a C64 PSU to the Core and SID" and I just got confused with all the different power connections. The schmetic shows two switches, can I just use 1 switch?Anyhelp would be greatly appreciated.
illogik Posted May 20, 2005 Posted May 20, 2005 The way I understand it is, I can take 5Vdc from the C64 PSU to J1 on the Core and 12Vac from the C64 PSU to J1 of the SID and both circuits will be powered? Do I have to connect power to anywhere else? I was looking at the schmetic of "how to connect a C64 PSU to the Core and SID" and I just got confused with all the different power connections. The schmetic shows two switches, can I just use 1 switch?just follow the schematic http://www.ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdf if you have only one core+sid--> look at the core4sid4 connections you need the 2 switches if you want to be able to turn your sid off (without having to pull out the power supply) it switches both the supplies (9V, 5V) off so both modules will be off. single switch is asking for trouble...good thing is that you can buy switches which have 2 switches inside (SPDT? i never get these terms right..) anyway good luck, marcel
k-rite Posted May 20, 2005 Author Posted May 20, 2005 good thing is that you can buy switches which have 2 switches inside (SPDT? i never get these terms right..)2 switches inside one switch!!! Awsome! What will the come up with next. ;DThanks for the help, I should be able to get this thing powered.
banneduser Posted May 20, 2005 Posted May 20, 2005 Yeah!Nice, You'll need that second switching for the AC----- I think??Bye, Moebius
Tanstaafl Posted May 21, 2005 Posted May 21, 2005 it might be a ... DPDT double pole double throw switch yer thinking of Marcel.i could be wrong... (and if I were Adrian Monk, i would follow this with)but i'm not. ;D
