Hi folks!
I've just finished my little 25 note midibox keyboard!
I've based the code on the MIDIIO128  and done some customizing to the code:
+1 octave transposer button
-1 octave transposer button
+1 semitone transposer button
simple 16 note sequencer (like on my beloved PROONE synth :-*)
Now I would like to store the 16 notes of the sequence into memory so I can powerOff and recall them later.
I used 17 variables in app_defines as follows:
;; INTERNAL 16 STEP SEQUENCER NOTES
SEQ1                    EQU 0x030
SEQ2                    EQU 0x031
SEQ3                    EQU 0x032
SEQ4                    EQU 0x033
SEQ5                    EQU 0x034
SEQ6                    EQU 0x035
SEQ7                    EQU 0x036
SEQ8                    EQU 0x037
SEQ9                    EQU 0x038
SEQ10                   EQU 0x039
SEQ11                   EQU 0x040
SEQ12                   EQU 0x041
SEQ13                   EQU 0x042
SEQ14                   EQU 0x043
SEQ15                   EQU 0x044
SEQ16                   EQU 0x045
;; LOOP POINT(number of recorded notes)
SEQNBR                  EQU 0x046
I'm struggling with the MIOS_FLASH_Read/write functions
and havent a clue how to store and recall 0x030...0x046
many thanks for an example or explination
Alkex
Hi Alkex,
I would suggest to store such data into EEPROM instead of Flash - in flash you can only write 64 bytes at once, and it reduces your code space. EEPROM is byte writeable, and the usage of MIOS_EEPROM_Write and MIOS_EEPROM_Read is much easier (no RAM buffer required)
the EEADR 0x60..0xff are not used by the MIDIO128 application yet
