TK. Posted June 13, 2005 Posted June 13, 2005 it seems to be the first MIDImon in the gallery :)Seppoman wrote:This is a box with the MidiMon app on it. I suppose most people only use this app on their "real" MidiBoxes for troubleshooting, but as I had this 4x20 display laying around anyway I thought it´d come handy sometime to have a MidiMon ready when needed. Theres´s nothing special about the construction, except the first photo shows you can also put the needed pull up resistors directly on the bottom side of the connector. Just cut one leg very short and the other bent one a bit longer so that the long one is just touching the +5V rail when the short one is soldered to the connector pin. If you do it right there´s no danger of short cirquits etc.
