kris Posted July 6, 2005 Posted July 6, 2005 hey up i just wondered if anybody made a controller for video mixing ive started using resolume and i want to make a controller to use with it
tgp Posted July 6, 2005 Posted July 6, 2005 with Jitter (a Max/MSP derivitive) you can control video with any controller you want. midi devices included. might want to check it out.
tazumi Posted July 12, 2005 Posted July 12, 2005 hi,almost every parameter in resolume can be controlled via midi. so it should be no problem.. just take your favourite mios-application and build a nice frontpanel.(do vjs use step-sequencer for modulation? i think it would be cool for example to jump to different frames via stepsequencer :-)g. tz
kris Posted July 22, 2005 Author Posted July 22, 2005 thanx the step sequencer idea is good im designing a layout for reasolume at the moment but ive not used it much so got to keep practicing before i get the ideal lay out so thats why i wondered if any body had done something alreadythanx kris
levon Posted July 26, 2005 Posted July 26, 2005 i use resolume as well, and im planning to make a midi controller at the end of the year. resolume just uses any midi device, so its more of what layout you want.... make it... and it should work rather easily. there is a resolume specific controller being made atm, for sale... not using MIOS. but there are pictures of the design of it http://www.resolume.com/react/index.php
