tatapoum Posted July 16, 2005 Posted July 16, 2005 Hi,Working hard on my futur 4 SIDsBox, I'm planning to add the Enveloppe Curve parameters control.As seen on Chriss design, 3 LEDs where added in the enveloppe section of the front panel.But isn't it more easily achievable by dedicating the assignable row of encoders to Attack Curve, Decay Curve, Release Curve and Delay (and maybe a All Curve).The Curve option is not well documented.Thanks,ludo
TK. Posted July 17, 2005 Posted July 17, 2005 Hi Ludo,the two software implemented envelopes don't provide a delay... or do you mean depth?There is only one "curve intensity" parameter for each envelope, and this feature can be assigned to attack/decay/release (in any combination)Best Regards, Thorsten.
tatapoum Posted July 17, 2005 Author Posted July 17, 2005 Hi TK,Thanks for the explanation about the curve parameter behaviour.Concerning the Delay I mixed with the Oscillators, that's a mistake.I've seen in a previous post that you suggested to use curve pot instead of sustain. But I've to test that before ordering the front panel... I will try on a pizza box ;).Thank you,ludo
