Working hard on my futur 4 SIDsBox, I'm planning to add the Enveloppe Curve parameters control.
As seen on Chriss design, 3 LEDs where added in the enveloppe section of the front panel.
But isn't it more easily achievable by dedicating the assignable row of encoders to Attack Curve, Decay Curve, Release Curve and Delay (and maybe a All Curve).
The Curve option is not well documented.
Thanks,
ludo
Hi Ludo,
the two software implemented envelopes don't provide a delay... or do you mean depth?
There is only one "curve intensity" parameter for each envelope, and this feature can be assigned to attack/decay/release (in any combination)
Hi TK,
Thanks for the explanation about the curve parameter behaviour.
Concerning the Delay I mixed with the Oscillators, that's a mistake.
I've seen in a previous post that you suggested to use curve pot instead of sustain. But I've to test that before ordering the front panel... I will try on a pizza box ;).
Thank you,
ludo
