I'm just wondering if anyone could tell me what type of power switch the one built into the normal brown C64 is?
Is it the dual type? If so, how do I connect it up? There are 6 pins. Do I just ignore the middle ones?
Thanks
Hi!
It is dual.... I don´t exactly know if it is really important wich pins you use....  take the right side of the pins for the first switched voltage, the left for the other to be switched..... check the pins with a beeper (multimeter) to be shure wich pins u can use...
hope this helps,....
pwx ???
