dcreatorx Posted August 5, 2005 Report Posted August 5, 2005 Hi , i want to ask what is the best way to create a SID speaking on power terms. I mean what advantages you got if you build one with 4 SID's instead of one with 2 ? And . . what's the best, use 4 8580 C128, 4 6581, or mixing them ? Thanks. ??? Quote
Jurbo Posted August 6, 2005 Report Posted August 6, 2005 More SIDs means that a greater number of different sounds can be played simultaneously. But in practice, the MBSID engine is so powerful and versatile, that you have a very broad range of sonic possibilties by using even just one SID. I'd say that one SID with the full control surface will get you a lot further into the SID realm than four SIDs with minimal control surface, as the exploring and and fine tuning the sounds is so much more fun and easy with a decent set of knobs at your hands. ;)About the different chips - the 8580 and 6581 do sound very different, and even the 6581's have much variation between them (the 8580's seem to be more similar to each other). So you really have to HEAR the different chips to know what YOU prefer. I started my box intending to build a 1x8580 / 1x6581, then ended up building it a 2x8580 but just some days ago I switched back to the original configuration with a 1x8580 / 1x6581 configuration which I think I'll settle with. Do a search - there is a thread on this forum where people excange their opinions on the different SIDs - but you can't really know how the chips compare by verbal definitions only. You have to hear them side-by-side yourself (by the way, comparing SID chips is a big part of the fun)! ;D Quote
dcreatorx Posted August 6, 2005 Author Report Posted August 6, 2005 Thank you . . i think i will create a two SID board so . . it was a very good explanation, thanks a lot ! Quote
