smycza Posted August 15, 2005 Report Posted August 15, 2005 Hi Everyone !When I bought my first PIC - my friend programmed it on a prof. programmer.When I put it into the socket (CORE) I was getting the 'sign of life' from PIC. But when I tried to send MIOS via MIDI something messed up andit started to send some pitch and reset data (weird..). So I built MBPH_BURNER and I tried to program it again (since my friend couldn't program it again for me :( )Now - when I try do burn bootstraploader into my PIC18F452 it verifies it as ok.But when I read my chip - the config bytes are different from those from bootstraploader.hex(they are always 2600 0F0F 0100 0081 C00F E00F 400F). I tried it on 4 different PIC's - alway the same result.When I put PIC into the CORE's socket there is no "sign of life" and my MIDI IN port do not read anything (my MIDI is working fine - I've made loopback tests).So what could be the problem? Is it the false CONFIG or did something blown-up when I tried to upload MIOS via MIDI ?I checked PCB - it seems to be ok.Please help me if You can, cause I cannot sleep anymore because of this ;)best regards, smycza
TK. Posted August 15, 2005 Report Posted August 15, 2005 Hi,you can ignore this mismatch, in the .hex file all unimplemented bits in the config sector are 1, but the PIC returns 0 for such bitsBest Regards, Thorsten.
