js Posted August 24, 2005 Report Posted August 24, 2005 I´ve almost managed so finish my Double (soon to be triple) Sid with CS. So far i´ve found the solution to the things i´ve messed up, but i cant seem to figure this one out.I´m using a 2x40 LCD and need to configure the additional selectbuttons 6-10. I´ve connected them to sr10 and compiled this code:[pre]//cut, more code upDIN_ENTRY CS_MENU_BUTTON_Dec, 1, 0 ; only valid if rotary encoder not assigned to these pinsDIN_ENTRY CS_MENU_BUTTON_Inc, 1, 1 ; (see mios_tables.inc) and CS_MENU_USE_INCDEC_BUTTONS == 1DIN_ENTRY CS_MENU_BUTTON_Exec, 1, 2DIN_ENTRY CS_MENU_BUTTON_Sel1, 1, 7DIN_ENTRY CS_MENU_BUTTON_Sel2, 1, 6DIN_ENTRY CS_MENU_BUTTON_Sel3, 1, 5DIN_ENTRY CS_MENU_BUTTON_Sel4, 1, 4DIN_ENTRY CS_MENU_BUTTON_Sel5, 1, 3DIN_ENTRY CS_MENU_BUTTON_Sel6, 10, 0 ; define this if CS_MENU_DISPLAYED_ITEMS > 5DIN_ENTRY CS_MENU_BUTTON_Sel7, 10, 1 ; define this if CS_MENU_DISPLAYED_ITEMS > 5DIN_ENTRY CS_MENU_BUTTON_Sel8, 10, 2 ; define this if CS_MENU_DISPLAYED_ITEMS > 5DIN_ENTRY CS_MENU_BUTTON_Sel9, 10, 3 ; define this if CS_MENU_DISPLAYED_ITEMS > 5DIN_ENTRY CS_MENU_BUTTON_Sel10, 9, 5 ; define this if CS_MENU_DISPLAYED_ITEMS > 5//Cut, more code down[/pre]Is there another place that i need to tell mios to use sr10?I´ve set i to use a 2x40 display in main.asm and the display works fine, i´ve also tried to set the buttons on sr9 instead and that works fine (but the other buttons I connect to sr10 (or sr11 for thet matter) doesn´t work)Any response is much appreciated!!! :)js
raphael Posted August 24, 2005 Report Posted August 24, 2005 Search for the following code in main.asm:;; initialize the shift registersmovlw 0x09 ; use up to 9 shift registers (maximum would be 16!)call MIOS_SRIO_NumberSetand replace 0x09 by 0x0A.Raphael
js Posted August 24, 2005 Author Report Posted August 24, 2005 THANKS ALOT!!!I had a feeling that it had to be sometheing simle i´ve missed and you hit it right on the spot!! :)Wonderful with this forum where people are so helpful and quick to respond!!Thanks again, it´s working perfect now (still need a few things:
