TK. Posted February 3, 2003 Posted February 3, 2003 ...without documentation about the different possibilities yet, and therefore no official release.Downloads:http://www.ucapps.de/midibox16e/midibox16e_v1004.hex.ziphttp://www.ucapps.de/midibox_mf/midibox_mf_v1000.hex.ziphttp://www.ucapps.de/midibox/mk_syx.ziphttp://serge.ucapps.deThe mk_syx archive contains some example configurations for LC and Houston emulation. As you can see, I haven't re-engineered all buttons of the Houston controller yet (it's only a question of effort...) but if somebody would like to complete the list: step forward! :)I've planned to write HOWTOs for both emulation types, but it could take a while...Best Regards, Thorsten.
TK. Posted February 4, 2003 Author Posted February 4, 2003 Now also the MIDIbox64 can be used to emulate a Houston or Mackie/Logic Control. :)However, only the Houston mode is really useful, since the protocol works with absolute values (for faders and V-pots!) and since you can connect a 2x40 LCD to the MIDIbox64. The Mackie emulation is unusable without rotary encoders and a larger display...The new firmware features also LED mapping and MIDIbox Linkhttp://www.ucapps.de/midibox/midibox64_v101.ziphttp://www.ucapps.de/midibox/mk_syx.zipBest Regards, Thorsten.
Cyril Posted February 4, 2003 Posted February 4, 2003 The new firmware features also LED mapping... Does this mean that I can assign LED no2 to Button no15 for example? In fact I don't understand how LED's are behaving with midibox 64... :-/ Was every LED already assigned to one Button before the new firmware?
TK. Posted February 4, 2003 Author Posted February 4, 2003 Hi Cyril,not every particular LED can be assigned, but the DOUT registers (group of 8 LEDs).In the old firmware the DOUT registers were statically assigned to the DINs:DOUT1 <= DIN2 and MIDI statusDOUT2 <= DIN3 and MIDI statusDOUT3 <= DIN1 and MIDI statusDOUT4 <= DIN4 and MIDI statusDOUT5 <= DIN5 and MIDI statusDOUT6 <= DIN6 and MIDI statusDOUT7 <= DIN7 and MIDI statusDOUT8 <= DIN8 and MIDI status("DINx and MIDI status" means: each digitial output is controlled by a button and by the appr. incoming MIDI event which is assigned to that button)The strange DIN/DOUT mix was necessary, because most people used only three DINs and two DOUTs - DIN1 has some dedicated functions (navigations buttons) which don't require a LED.But with the special function buttons and especially the Houston/LC emulation, a more flexible solution was necessary-> the LED maps.With LED maps you can mix the DIN->DOUT assignments like you want. And it is also possible to assign the DOUTs to other functions:DOUTx <= MIDI status of DINx only (necessary for the emulation modes, where solely the host application has to control the LEDs)DOUTx <= internal/external Bank number (in theory, also a LED digit could be driven by one DOUT register)and planned for MIDIbox64SEQ:DOUTx <= Sequencer Pos of current track (left/right part)DOUTx <= Sequencer Pos of track 1/2/3/4 (left/right part)However, it will be more clear when you are able to play with the different settings. :)Best Regards, Thorsten.P.S.: from midibox16e.ini################################################################################ # LED Map: assignes the LED shift registers to the Button Shift # registers or special values # Currently following values are supported: # 0 Default Setting (see Map below) # 1 Button Shift Register 1 (Button ID #1-#8) # 2 Button Shift Register 2 (Button ID #9-#16) # 3 Button Shift Register 3 (F1-F4 and Navigation Buttons: ID #17-#24) # 4 Button Shift Register 4 (Button ID #25-#32) # 5 Button Shift Register 5 (Button ID #33-#40) # 6 Button Shift Register 6 (Button ID #41-#48) # 7 Button Shift Register 7 (Button ID #49-#56) # 8 Button Shift Register 8 (Button ID #57-#64) # 9 Internal Bank (1 of 8) # 10 External Bank (1 of 8) # 11-15 reserved # 16 MIDI Status received for Button ID #1-#8 ([MIDI_LEDS] must be enabled!) # 17 MIDI Status received for Button ID #9-#16 ([MIDI_LEDS] must be enabled!) # 18 MIDI Status received for Button ID #17-#24 ([MIDI_LEDS] must be enabled!) # 19 MIDI Status received for Button ID #25-#32 ([MIDI_LEDS] must be enabled!) # 20 MIDI Status received for Button ID #33-#40 ([MIDI_LEDS] must be enabled!) # 21 MIDI Status received for Button ID #41-#48 ([MIDI_LEDS] must be enabled!) # 22 MIDI Status received for Button ID #49-#56 ([MIDI_LEDS] must be enabled!) # 23 MIDI Status received for Button ID #57-#64 ([MIDI_LEDS] must be enabled!) # 24-31 reserved ################################################################################ [LED_MAP] LED_SR1 = 1 # (Button ID #1-#8) LED_SR2 = 2 # (Button ID #9-#16) LED_SR3 = 3 # (F1-F4 and Navigation Buttons: ID #17-#24) LED_SR4 = 4 # (Button ID #57-#64) LED_SR5 = 5 # (Button ID #25-#32) LED_SR6 = 6 # (Button ID #33-#40) LED_SR7 = 7 # (Button ID #41-#48) LED_SR8 = 8 # (Button ID #49-#56)
Cyril Posted February 4, 2003 Posted February 4, 2003 Thanks Thorsten!That sounds Great! I'll take out my JDM and (re)program my PIC ;)My midibox is under construction and I've just ordered my pots. Can't wait to see all that working... ;D
