gotascii Posted August 27, 2005 Report Share Posted August 27, 2005 Pretty much summed up in the topic. Any ideas why only my CS pin would pass the sid interconnect test? Quote Link to comment Share on other sites More sharing options...
gotascii Posted August 27, 2005 Author Report Share Posted August 27, 2005 im assuming pins 23 and 29 on the pic should send some voltage when i send mod wheel events to the pic correct? Testing the voltage directly from these two pins shows 0v no matter what i send to the pic. The voltage on pin 24 does respond to mod wheel #14. can anyone make sense of what my problem is? Quote Link to comment Share on other sites More sharing options...
gotascii Posted August 28, 2005 Author Report Share Posted August 28, 2005 For some reason I kept reading the note about the SC pin (mbhp_sid_c64_psu.pdf) as "Only use this is you have a pic16f" Just goes to show that the "read the directions" skill I learned in 2nd grade still applies. The good news is after I connected that EVERYTHING WORKS! Hearing sound from my sid for the first time was awsome! ty for all the help here on the forums :D Quote Link to comment Share on other sites More sharing options...
TK. Posted August 28, 2005 Report Share Posted August 28, 2005 Great :)Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
