Here is a tip for all the ppl using Logic in Windows XP:
Create a text file
Copy paste the following using notepad or any editor:
[tt]<?xml version="1.0" encoding="UTF-8" standalone="yes"?><assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0"><assemblyIdentity version="1.0.0.0" processorArchitecture="X86" name="CompanyName.ProductName.YourApp" type="win32"/><description>Your application description here.</description><dependency> <dependentAssembly> <assemblyIdentity type="win32" name="Microsoft.Windows.Common-Controls" version="6.0.0.0" processorArchitecture="X86" publicKeyToken="6595b64144ccf1df" language="*" /> </dependentAssembly></dependency></assembly>[/tt]
Save the file.
Copy the file to Logic directory
Rename as the filename suggests eg for logic 5.5
Logic Platinum 5.5.0.exe.manifest
Run logic and observe the differencies on the dialog more XP styled.
This tip is useles with the steinberg products cubase, wavelab ( I thing they using Borland libraries and not the standard MS API).
Happy sequencing  ;D ;D ;D
PS. Thorsten bring the MIOS even undocumented (at least to me as I am alpha and  beta tester) :) :) :)
