Hello
at last I have ended up I all my first mdibox64 v2.4, configuration comes from LCD 4X20, 32 pots, 8 faders, 56 buttons, 56 leds and 4 encoders alps 24 p detented connected in my second din module ( sr8 ).
The encoder work like double push buttons, I need to increment and decrement the value of  a midi CC,( like a pot )
my knowledge of English language is too small and I think that I have not understood how to configure  encoders
I have modified the mios_tables.inc  file ,only the lines like show you get down , the rest of the file is the same as the original
I thank your help.
Apologizing my error when inserting this post at the section latest news
Greetings
MIOS_MPROC_EVENT_TABLE
   ;; entry 0x00-0x0f
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   ;; entry 0x10-0x1f
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
                     MT_EOT
   MT_EOT
   MT_EOT
   MT_EOT
   MT_ENTRY  0xb0, 0x1b
   MT_ENTRY  0xb0, 0x1c
   MT_ENTRY  0xb0, 0x1d
   MT_ENTRY  0xb0, 0x1e
   MT_ENTRY  0xb0, 0x1f
MIOS_ENC_PIN_TABLE
   ;; encoders 1-16
   ;;        SR  Pin  Mode
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
                      ENC_EOT
   ENC_EOT
   ;; encoders 17-32
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
   ENC_EOT
                     ENC_ENTRY  8,  0,  MIOS_ENC_MODE_DETENTED2   ; V-Pot 29
   ENC_ENTRY  8,  2,  MIOS_ENC_MODE_DETENTED2   ; V-Pot 30
   ENC_ENTRY  8,  4,  MIOS_ENC_MODE_DETENTED2   ; V-Pot 31
   ENC_ENTRY  8,  6,  MIOS_ENC_MODE_DETENTED2   ; V-Pot 32
I think it could be a prob with the EOT message. It´s also stated in the .asm file: When MIOS is reading the *first* EOT message, it won´t search anymore for the correct entry. So all your needed entries should fill up the first lines of the table and the rest then should be filled with EOT messages. Not sure about that, but could be... *pushingthumbs*
the encoder's behavior has changed after modifying the file.
Turning clockwise send data even pins, turning counterclockwise send data odd pins.
That's right?
how configure the events to increment and decrement the value of  CC.
¿It is possible to increase in 2 ,4 ,8 ...each step ?
tanks
I don´t know if that´s normal, but if you want to do CC changes with the Encoders you should use MB64E firmware and not MB64. MB64 is thought to work only with pots as MB64E works with pots & Encoders. Check it on UCApps.de for more info: http://www.ucapps.de/midibox16e.html
