leelinn Posted October 10, 2005 Report Posted October 10, 2005 Hello,i solved my prblems with JDm (i don't know how!!).I pass all checks with my meter(expcept for read all --->i obtained 8,7V instead 13,7V but it seems that under Windows Xp it's impossible to reach this value).Now i have to put into pic the mios: but 1.7a or 1.8? What is the difference?At the moment i put into pic (operation complete successfully) 1.7a. The question is this: i found many hex files and i put into pic only §"main.hex". Is the right one? And the other hex files?If i want to put into pic the mios 1.8 what will i do? I have to erase the old mioand put the one? Is it necessary to repat all test for the same jdm module again?tnx for supportleelinn
raphael Posted October 11, 2005 Report Posted October 11, 2005 Now i have to put into pic the mios: but 1.7a or 1.8? What is the difference?http://www.ucapps.de/mios_changelog.htmlAlways take the latest one --> V1.8At the moment i put into pic (operation complete successfully) 1.7a. The question is this: i found many hex files and i put into pic only §"main.hex". Is the right one? And the other hex files?If i want to put into pic the mios 1.8 what will i do? I have to erase the old mioand put the one? Is it necessary to repat all test for the same jdm module again?There is only one hex-file in the MIOS package: mios_v1_8.hexTake this one!And what are you talking about JDM and MIOS ???Just burn the Bootstrap loader with your JDM (http://www.ucapps.de/mios_bootstrap.html) and upload MIOS via MIDI (Best way is MIOSStudio: http://miosstudio.midibox.org/)When the Bootloader is burned all right you can Upload MIOS and applications via MIDI as often as you want to.Rapael
