Hi all,
I've just finished my DIN, connected it to the core,  :D tried to simulate a bouton by sending ground to one of the entries but ... seems like my program does not see any button pressed  >:(.
I display a message in the DIN_NotifyToggle( ) function (I'm using C language) but it never appears on my LCD.  :-\
Does it take some other parameter to activate use of the buttons ? Where am I going wrong ?
Thanks all
Yes, you have to specify the number of shift registers and the update frequency within Init():
void Init(void) __wparam
  // initialize the shift registers
  MIOS_SRIO_NumberSet(16); // shiftregisters
  MIOS_SRIO_UpdateFrqSet(1); // mS
[/code]
Waow hello Holy Father and thanks for this help coming from the skies  ;D :D
Now it works perfectly well  8)
By the way, thanks for this great geeky project, that gives lot of fun !!!
Seeya,
Goule
So you have an application that can display which din is toggled? or did I get you wrong?
If yes, could you give it to me as I am hunting for bad solderjoints in my mblc, it seems like not
all din pins are properly working yet so such a test-app would be usefull.
greetings
rambinator
