I have a very simple midi keyboard with Midi in/out sockets. Can someone please explain why when I connect keyboard-->midibox-->pc I can't use snap/relative/parallax mode.
I'm not sure I understand this.
If this is true, and if I don't have midi thru socket on my midi keyboard than I will not be able to use them both in the same time?
Thanks.
I was afride of the answer.
And what about this configuration (since I don't have midi thru on my midi keyboard):
keyboard out -> midibox in
midibox out -> pc in
does this make sense? if yes, will it work with snap/relative/parallax mode?
Thanks
If your keyboard has no Thru port, it possibly also provides an integrated merger - this would be perfect!
Which keyboard do you own exactly?
I wish. Currently, my midi keyboard is something I got from my nefue. It is not even remotly a professional keyboard. And BTW, it has only MIDI OUT, not MIDI in/out as I mistakably said in the intial postings. This keyboard only outputs.
I will upgrade soon, but now I'm investing all my "hobby" budget on the midibox64.
So I guess no chance here Aha? Is there any solution to this problem?  ???
Thanks.
