experimental Posted December 5, 2005 Report Posted December 5, 2005 Is there a B40C800 in the C64 that i can use for the power supply?I see something that I think might be it located at C4 on the board (mine is assy no 250407 rev A) Am i correct?Thanks-
pwx Posted December 6, 2005 Report Posted December 6, 2005 Hi!is it that one? www.alldatasheet.com/datasheet-pdf/pdf/82594/MICROSEMI/VJ1048M.htmlI think u can use it..... please correct me if I´m wrong!! :Dpwx
experimental Posted December 6, 2005 Author Report Posted December 6, 2005 I do see one, and only one like it on the c64 board, i just wasnt 100% sure that it is the correct one.Unless someone else chimes in, i will extract it and see if it works-THanks-
raphael Posted December 6, 2005 Report Posted December 6, 2005 If it is the one on pwx's datasheet, it will work.
experimental Posted December 7, 2005 Author Report Posted December 7, 2005 Mine is labeled "S2VB" like this one http://pdf.alldatasheet.com/datasheet-pdf/view/43994/SHINDENGEN/S2VB20.htmlLook ok?
