goule Posted December 23, 2005 Report Posted December 23, 2005 Hello crew ;DMy MBHP has come to some satisfying point, but I still need to connect those bluddy rotary encoders (both detended, one with switch) to my working DIN (already 4 buttons on it that works perfectly well).I didn't find any scheme on ucapps.de that would show me how to solder those babies on the PCB.Could you please help ??Thannxxxxx 8)Goule
seppoman Posted December 24, 2005 Report Posted December 24, 2005 Hi,everything´s on uCapps. As it is to be expected, connections to a DIN board are explained on http://www.ucapps.de/mbhp_din.html - just look under "Additional information".Even if you have an encoder type not mentioned on this page, there are only 3 pins coming from an encoder and you can swap them as you like until it works as intended. You can´t damage anything.Merry Christmas,Seppoman
goule Posted December 24, 2005 Author Report Posted December 24, 2005 Hello,Thanx for reply and greetings :DOne of my encoders have 5 pins that's why I wrote I didn't find the corresponding scheme. Anyway, I think the logic is the same (3 for rotary + 2 for switching ?)Merry christmas and a happy new year for you and all that midibox tribe 8)Goule
moebius Posted December 24, 2005 Report Posted December 24, 2005 One of my encoders have 5 pins that's why I wrote I didn't find the corresponding scheme. Anyway, I think the logic is the same (3 for rotary + 2 for switching ?)Yes.Probably the encoder with a switch has 2 pins on the second side. Those are switch contacts.Bye, Moebius
goule Posted December 30, 2005 Author Report Posted December 30, 2005 Yes it finally worked that way. Thanks to all :DGoule
