Guest faz909 Posted February 22, 2003 Report Share Posted February 22, 2003 Hi Thorsten, all..I've been following the MIDIBox developments for a while now.. you cease to amaze me with your ideas.. Well Done!!I'm trying to work out the equations in Logic Controls challenge/response code..  (please excuse my lack of knowledge, I'm a novice) .. r1 = 0x7F & (l1+(l2^0xA)-l4)  r2 = 0x7F & ((l3>>4)^(l1+l4))  r3 = 0x7F & (l4-(l3<<2)^(l1|l2)  r4 = 0x7F & (l2-l3+(0xF0^(l4<<4)))In my readings, I've learnt about the different operations.. AND, XOR, LSHIFT, RSHIFT, OR.. I've found a calculator that handles algebraic equations.. but I have no idea if I understand it or not.. I do have some answers.. can someone please tell me if I'm right or wrong?  if  L1  =  8  then R1 = 22if  L2  =  16  then R2 = 14if  L2  =  32  then R2 = 127if  L2  =  12  then R2 = 32I'm also confused with the 7 byte ASCII serial number.. I don't own a Logic control, so I don't know what a serial number looks like, it's format.. Is there a format for LC serial numbers? Is the random challenge code random each time LC turns on, or is it dependant on the serial no.?I'm sending sysex messages between two PC's, with one of them trying to emulate a LC power up using sysex faders.As you can see, I'm confused, and need some help to understand all this.. Thanks in advance..Faz Quote Link to comment Share on other sites More sharing options...
TK. Posted February 22, 2003 Report Share Posted February 22, 2003 Hi Faz,it isn't required to send the decoded password to Logic or Cubase, some dummy bytes are enough, since the purpose of this nameization sequence is only to unlock the Logic Control itself. Here the appr. code for the MIOS application, which will be published soon (and which can give you some more hints). These parts are called by a SysEx parser, which reacts on F0 00 00 66 <LC-ID> <action-ID>: ;; -------------------------------------------------------------------------- ;; MIDI Check action: perform a sysex action ;; -------------------------------------------------------------------------- LC_MPROC_Handler IFSET LC_MPROC_STATE, LC_MPROC_STATE_ACTION, rgoto LC_MPROC_Handler_DoAction bsf LC_MPROC_STATE, LC_MPROC_STATE_ACTION movff LC_MPROC_IN, LC_MPROC_ACTION rgoto LC_MPROC_SysExCheck_End ;; --- LC_MPROC_Handler_DoAction movf LC_MPROC_ACTION, W bz LC_MPROC_Action_Query movf LC_MPROC_ACTION, W xorlw 0x02 bz LC_MPROC_Action_HostReply movf LC_MPROC_ACTION, W xorlw 0x10 bz LC_MPROC_Action_WriteMTC1 movf LC_MPROC_ACTION, W xorlw 0x11 bz LC_MPROC_Action_WriteMTC2 movf LC_MPROC_ACTION, W xorlw 0x12 bz LC_MPROC_Action_WriteLCD movf LC_MPROC_ACTION, W xorlw 0x13 bz LC_MPROC_Action_VersionReq goto LC_MPROC_ActionInvalid ;; -------------------------------------------------------------------------- ;; MIDI Action: LC Query ;; -------------------------------------------------------------------------- LC_MPROC_Action_Query ;; wait until sysex footer (F7) has been received movlw 0xf7 IFNEQ LC_MPROC_IN, ACCESS, rgoto LC_MPROC_SysExCheck_End ;; send SysEx header call LC_MPROC_Send_SysExHeader ;; send Host Connect Query movlw 0x01 call MIOS_MIDI_TxBufferPut ;; call help function which sends the LC serial number call LC_MPROC_Hlp_SendSerial ;; send dummy password movlw 'A' call MIOS_MIDI_TxBufferPut movlw 'B' call MIOS_MIDI_TxBufferPut movlw 'C' call MIOS_MIDI_TxBufferPut movlw 'D' call MIOS_MIDI_TxBufferPut ;; send SysEx footer call LC_MPROC_Send_SysExFooter ;; finish Action rgoto LC_MPROC_ActionFinished ;; -------------------------------------------------------------------------- ;; MIDI Action: LC Host Reply ;; -------------------------------------------------------------------------- LC_MPROC_Action_HostReply ;; wait until sysex footer (F7) has been received movlw 0xf7 IFNEQ LC_MPROC_IN, ACCESS, rgoto LC_MPROC_SysExCheck_End ;; send SysEx header call LC_MPROC_Send_SysExHeader ;; send Host Connect Confirmation movlw 0x03 call MIOS_MIDI_TxBufferPut ;; call help function which sends the LC serial number call LC_MPROC_Hlp_SendSerial ;; send SysEx footer call LC_MPROC_Send_SysExFooter ;; finish Action rgoto LC_MPROC_ActionFinished ;; -------------------------------------------------------------------------- ;; this help function sends the pseudo serial number of the emulation: 12345678 LC_MPROC_Hlp_SendSerial movlw '1' movwf TMP1 LC_MPROC_Hlp_SendSerial_Loop movf TMP1, W call MIOS_MIDI_TxBufferPut incf TMP1, F movlw '8' IFNEQ TMP1, ACCESS, rgoto LC_MPROC_Hlp_SendSerial_Loop return ;; -------------------------------------------------------------------------- ;; MIDI Action: LC Version Request ;; -------------------------------------------------------------------------- LC_MPROC_Action_VersionReq ;; wait until sysex footer (F7) has been received movlw 0xf7 IFNEQ LC_MPROC_IN, ACCESS, rgoto LC_MPROC_SysExCheck_End ;; send SysEx header call LC_MPROC_Send_SysExHeader ;; send version number movlw 0x14 call MIOS_MIDI_TxBufferPut movlw 'V' call MIOS_MIDI_TxBufferPut movlw '1' call MIOS_MIDI_TxBufferPut movlw '.' call MIOS_MIDI_TxBufferPut movlw '4' call MIOS_MIDI_TxBufferPut movlw '2' call MIOS_MIDI_TxBufferPut ;; send footer only if merger has not been enabled ;; to ensure a proper MIDI protocol call MIOS_MIDI_MergerGet andlw 0x01 bnz LC_MPROC_Action_VersionReq_End movlw 0xf7 call MIOS_MIDI_TxBufferPut LC_MPROC_Action_VersionReq_End rgoto LC_MPROC_ActionFinished there is no special format for the version numberHope it helpsBest Regards, Thorsten.P.S.: maybe it's required to handle this SySEx interaction (Query/Reply/Version Request) as fast as possible before the host application sends the query command again!) Quote Link to comment Share on other sites More sharing options...
