LC Initialization
Guest faz909
Hi Thorsten, all..
I've been following the MIDIBox developments for a while now.. you cease to amaze me with your ideas.. Well Done!!
I'm trying to work out the equations in Logic Controls challenge/response code..  (please excuse my lack of knowledge, I'm a novice)
.. r1 = 0x7F & (l1+(l2^0xA)-l4)
  r2 = 0x7F & ((l3>>4)^(l1+l4))
  r3 = 0x7F & (l4-(l3<<2)^(l1|l2)
  r4 = 0x7F & (l2-l3+(0xF0^(l4<<4)))
In my readings, I've learnt about the different operations.. AND, XOR, LSHIFT, RSHIFT, OR.. I've found a calculator that handles algebraic equations.. but I have no idea if I understand it or not.. I do have some answers.. can someone please tell me if I'm right or wrong?
if  L1  =   8   then R1 = 22
if  L2  =  16  then R2 = 14
if  L2  =  32  then R2 = 127
if  L2  =  12  then R2 = 32
I'm also confused with the 7 byte ASCII serial number.. I don't own a Logic control, so I don't know what a serial number looks like, it's format.. Is there a format for LC serial numbers? Is the random challenge code random each time LC turns on, or is it dependant on the serial no.?
I'm sending sysex messages between two PC's, with one of them trying to emulate a LC power up using sysex faders.
As you can see, I'm confused, and need some help to understand all this..
Thanks in advance..
Faz
Hi Faz,
it isn't required to send the decoded password to Logic or Cubase, some dummy bytes are enough, since the purpose of this nameization sequence is only to unlock the Logic Control itself. Here the appr. code for the MIOS application, which will be published soon (and which can give you some more hints). These parts are called by a SysEx parser, which reacts on F0 00 00 66 <LC-ID> <action-ID>:
;;  MIDI Check action: perform a sysex action
LC_MPROC_Handler
        IFSET   LC_MPROC_STATE, LC_MPROC_STATE_ACTION, rgoto LC_MPROC_Handler_DoAction
        bsf     LC_MPROC_STATE, LC_MPROC_STATE_ACTION
        movff   LC_MPROC_IN, LC_MPROC_ACTION
        rgoto   LC_MPROC_SysExCheck_End
        movf    LC_MPROC_ACTION, W
        bz      LC_MPROC_Action_Query
        xorlw   0x02
        bz      LC_MPROC_Action_HostReply
        xorlw   0x10
        bz      LC_MPROC_Action_WriteMTC1
        xorlw   0x11
        bz      LC_MPROC_Action_WriteMTC2
        xorlw   0x12
        bz      LC_MPROC_Action_WriteLCD
        xorlw   0x13
        bz      LC_MPROC_Action_VersionReq
        goto    LC_MPROC_ActionInvalid
;;  MIDI Action: LC Query
        ;; wait until sysex footer (F7) has been received
        movlw   0xf7
        IFNEQ   LC_MPROC_IN, ACCESS, rgoto LC_MPROC_SysExCheck_End
        ;; send SysEx header
        call    LC_MPROC_Send_SysExHeader
        ;; send Host Connect Query
        movlw   0x01
        call    MIOS_MIDI_TxBufferPut
        ;; call help function which sends the LC serial number
        call    LC_MPROC_Hlp_SendSerial
        ;; send dummy password
        movlw   'A'
        movlw   'B'
        movlw   'C'
        movlw   'D'
        ;; send SysEx footer
        call    LC_MPROC_Send_SysExFooter
        ;; finish Action
        rgoto   LC_MPROC_ActionFinished
;;  MIDI Action: LC Host Reply
        movlw   0xf7
        ;; send Host Connect Confirmation
        movlw   0x03
        ;; finish Action
;; this help function sends the pseudo serial number of the emulation: 12345678
        movlw   '1'
        movwf   TMP1
LC_MPROC_Hlp_SendSerial_Loop
        movf    TMP1, W
        incf    TMP1, F
        movlw      '8'
        IFNEQ      TMP1, ACCESS, rgoto LC_MPROC_Hlp_SendSerial_Loop
        return
;;  MIDI Action: LC Version Request
        movlw   0xf7
        ;; send version number
        movlw   0x14
        movlw   'V'
        movlw   '1'
        movlw   '.'
        movlw   '4'
        movlw   '2'
        ;; send footer only if merger has not been enabled
        ;; to ensure a proper MIDI protocol
        call    MIOS_MIDI_MergerGet
        andlw   0x01
        bnz     LC_MPROC_Action_VersionReq_End
        movlw   0xf7
there is no special format for the version number
Hope it helps
P.S.: maybe it's required to handle this SySEx interaction (Query/Reply/Version Request) as fast as possible before the host application sends the query command again!)
