rogic Posted January 27, 2006 Posted January 27, 2006 Hello,a freind wants to make new midibox 64 or 64e, we're not sure yet, but we want following modules:1 CORE1 LTC1 AIN2 DIN1 DOUTand we're considering to put everything on one PCB board.does someone has and eagle file or picture of such combined PCB?thanks
pay_c Posted January 27, 2006 Posted January 27, 2006 I made something similar and this works good: Just take the standard PCBs from ucapps.de or smashtv´s PCBs and copy/paste it together as you need it onto you format (e.g. 160x100 with core+LTC+some DINs or so). The interconnections are then just soldered permanently.MUCH less effort than making everything new in Eagle and a piece of cake, too.The ready PCBs (for copy&paste) can also be found as .pdf´s in the portal of midibox.org.Greetz.
Tanstaafl Posted January 27, 2006 Posted January 27, 2006 I agree with pay_ci have quite a few custom boards I have done and each one seems to be specific to my application for that box.I have also found that cutting and pasteing is the best bet with a few hard wires.it won't be rocket science. My Moog Modular V is 2 X (6in. X 9in.) boards with1 core2 ains2 dinssorry no douts... but again... there's that connector for that and it's not rocket sciencehappy to give you the pdf's of these files... sorry I take eagle files, turn them into postscript files then edit them in photoshop to get wider runs and bigger pads... etc, etc, and of course, etc.......the final pdf's are printed 1:1 and work perfectly.good luck, and let me know if you want this stuffgb
rogic Posted January 31, 2006 Author Posted January 31, 2006 Hellogbeth, I would like to get those pdf files if possible. here is my email: rogic13 at hotmail dot comthe reason we would like to put modules on one board is that we would like to minimize cable makingfor module interconnections (and to avoid bad soldering), and to make bigger SIL sockets so we can usehard-drive cables (20 pins) betweek modules and interface
Tanstaafl Posted January 31, 2006 Posted January 31, 2006 No problem, I will forward to you in the next day or so. Let me know how they do or don't work out for you!gb
