tokyomatik Posted January 27, 2006 Posted January 27, 2006 i finally been able to upload the sid applicationthen i tryed to check my midibox with the interconnection testand i got this messagetest SID modulepin:A0what does it means?is my sid chip damaged or is something about the bad soldering?i'm looking at the pin and it looks good...any tips?
banneduser Posted January 27, 2006 Posted January 27, 2006 STOP!!Take your SID chip OUT before this test.Actually READ the main.asm for instructions, A0 means that this test application is testing SID chip pin A0 and it should be around 5VDC. ect.M
tokyomatik Posted January 27, 2006 Author Posted January 27, 2006 unluckily, now i don't have a tester with me,but, just to know, what kind of message should i get if all the connections are ok?
banneduser Posted January 27, 2006 Posted January 27, 2006 unluckily, now i don't have a tester with me,but, just to know, what kind of message should i get if all the connections are ok?You get that message in your head or maybe marked on the paper ;) Read the main.asm.You're testing, if signals from core are actually going to SID socket - manually, by sending different modulation control messages and seeing if PIN voltage goes up.. (read the main asm there's one exception) MEssages on the LCD only show which PIN is selected and you can see those pins in SID module schematics.M
tokyomatik Posted January 27, 2006 Author Posted January 27, 2006 ahahah funny guy that moebius! ;Dok, so basicly, in the lcd, the interconnection test shows me only the pins of the sid and nothing else, right?and even if instead of a keyboard i use logic or cubaseto see the values, anyway i need the multimeter, right?...just to know...
TK. Posted January 27, 2006 Posted January 27, 2006 to see the values, anyway i need the multimeter, right?yes, or a LED + resistor. Connect the cathode to ground, and the anode over a 220 Ohm...1k resistor to the pin which should be tested.
