tatapoum Posted February 23, 2006 Report Posted February 23, 2006 Hi all,I've start a flickr page to log my work in progress on my 4 SID MidiBox.ludo Quote
js Posted February 23, 2006 Report Posted February 23, 2006 Looks Very nice so far!!! ;)Much better that the crap i´ve put together :) (but I love my crap, and it surely has some personality :D )Going to try to make i a bit more quality the next time....Good work!! keep on ;)js Quote
sonicwarrior Posted February 23, 2006 Report Posted February 23, 2006 Nice PCB for the LED matrix.Can you post the etch layout here?Which switches have you used there? Quote
tatapoum Posted February 23, 2006 Author Report Posted February 23, 2006 Thanks for you positive feedbacks.I used switches from Voti for the matrix and Multimec 3F switches elsewhere. I hadn't bought illuminated ones, I've mounted the LED myself because the stuffed one are too much expensive.I will post the matrix PCB later because I'm not at home. Please note the PCB is double-side and that there is not enought room space to use the pads to connect the wire. So I've put the wire close to the LED and switches.ludo Quote
tatapoum Posted March 4, 2006 Author Report Posted March 4, 2006 The eagle PCB file is here.Here is a preview :ludo Quote
tatapoum Posted March 16, 2006 Author Report Posted March 16, 2006 Some new photos were posted and I'm glad to announce that sounds go out from the 4 SID. I found a dead C64 on e-bay and the 6581 sounds like a charm.But there is a lot of work left...ludo Quote
thefRont Posted March 17, 2006 Report Posted March 17, 2006 i've seen a printout of the frontpanel on one of your photos. do you want to drill it yourself or will you buy the panel somewhere? Quote
tatapoum Posted March 17, 2006 Author Report Posted March 17, 2006 Hi,As I was really satisfied by Schaeffer Apparatebau works on my SEQ front panel, so I will deal again with them. The print out was made with their software, Front Panel Designer.Cheers,ludo Quote
tatapoum Posted March 20, 2006 Author Report Posted March 20, 2006 New update here.One detail, the modules to control Enveloppes + Oscillators, Filters and LFOs.ludo Quote
experimental Posted March 27, 2006 Report Posted March 27, 2006 What are you using for power supply?Could you put up a close up photo of your power supply ??Thanks- Quote
thefRont Posted March 27, 2006 Report Posted March 27, 2006 looks like he has built his own psu with two transformators and some additional stuff for regulation, to get the needed voltages for the core and sid modules. Quote
tatapoum Posted March 27, 2006 Author Report Posted March 27, 2006 You're right thefRont, it's a simple PSU. I can put PCB in the forum.Here is a close-up of the PSU :ludo Quote
experimental Posted March 27, 2006 Report Posted March 27, 2006 Thanks! Would love to the see the PCB layout-How are you powering this PSU? Quote
tatapoum Posted March 27, 2006 Author Report Posted March 27, 2006 I'll post the PCB layout latter because I'm away from home.This PSU is powered on 220Vac (Main home power supply).ludo Quote
tatapoum Posted April 5, 2006 Author Report Posted April 5, 2006 The Eagle file is here.It is based on the Core design. Maybe 2200uF cap is a bit too low, but all boards have a 2200uF.ludo Quote
tatapoum Posted April 5, 2006 Author Report Posted April 5, 2006 Tonight work on flickr : upgrade Voti's encoder to non-detented mode..I really prefer Voti's encoder to SmashTV ones wich seems to be less precise.ludo Quote
stryd_one Posted April 6, 2006 Report Posted April 6, 2006 Thanks for sharing mate :)Geez I love this place. You guys rock. Quote
tatapoum Posted April 30, 2006 Author Report Posted April 30, 2006 Hardware work in progress here.ludo Quote
tatapoum Posted May 3, 2006 Author Report Posted May 3, 2006 Now I've to order the front panel...More photos here.ludo Quote
c0nsumer Posted May 4, 2006 Report Posted May 4, 2006 May I ask how you are planning on doing the window in front of the LCD? Without a milled piece of lexan / perspex / glass (with a stepped edge) and some milling around the edge of the opening for the LCD, I've been at a bit of a loss to come up with a cheap, durable, attractive window.-Steve Quote
tatapoum Posted May 4, 2006 Author Report Posted May 4, 2006 Hi Steve,I don't protect the LCD in anyway. There will be only a window in the front panel as made on my Midibox SEQ :.ludo Quote
c0nsumer Posted May 4, 2006 Report Posted May 4, 2006 I don't protect the LCD in anyway. There will be only a window in the front panel as made on my Midibox SEQAh, okay. I was wondering, since that's the problem I'd yet to solve. I haven't tried to contact a glass company to see if they could mill a lip into a piece of glass... Maybe I should do that. (Note, this is for a non-MIDIbox project.)Or, it may be possible to laminate two appropriately sized pieces of acrylic with a cyanoacrylate glue... Quote
tatapoum Posted May 9, 2006 Author Report Posted May 9, 2006 Why not to use a plate of acrylic like used for homebrew framing ? It's easily to found and cheap. You may put it between the LCD screen and the window. Glue it to avoid moves. ludo Quote
