My power supply works-
My Core works- loaded MIOS, and loaded SID OS with no problems.
My SID makes sounds- (noisy though)
My LCD is not happy-
It came with an adjustable resister, do I need to use it? and how does it get wired in?
When I hook the LCD up as it shows in the Schematic,  it is just bright backlight with no characters..
This is the display that I am using-
http://cgi.ebay.com/HD44780-New-16x2-LCD-Module-w-White-text-on-blue-PC-kit_W0QQitemZ7599019079QQcategoryZ26206QQrdZ1QQcmdZViewItem
Thanks!
Most often you can use the LCD schematic from UCApps.de. If it does not function, try using it the other way around (meaning just rotate the cable by 180°). In 80% the LCD should work the one or the other way.
Anyhow, I have no idea about the adjustable resistor. Just try the middle position first and then adjust it if needed.
Greets!
