LiFo Posted April 5, 2006 Report Posted April 5, 2006 is there any command you can sent to the display to get it to blinkor is it only the cursur that is blinkin or have i to programm it my self to blink ?if i have to make it blink my selv i was thinking about using a timer somhow i have only looked breafly at the function page and as i understand there are only 1 timer i can use was also thinking to use another timer to make one dout blink a diode indicating the tempo to get me started, some c examples using a timer would be realy great
Wild_Weasel Posted April 6, 2006 Report Posted April 6, 2006 Hi!The backlight is connected to the supply voltage via a resistor and a transistor and not to an I/O of the pic.Therefore the backlight (I am speaking about the led backlight here) can't be turned on or of. But I am sure you can get the letters to blink.Another way would be to to connect the backlight to an output of the DOUT Module.But I think this can only be done with the help of another transistor since the DOUT is not able to drive the backlight.RegardsM.
stryd_one Posted April 6, 2006 Report Posted April 6, 2006 LiFo did you mean making the backlight or the characters blink?
LiFo Posted April 6, 2006 Author Report Posted April 6, 2006 i ment the characters not the back light
moebius Posted April 6, 2006 Report Posted April 6, 2006 The answer is.................... In the bloody datasheet for hd44780!M
stryd_one Posted April 7, 2006 Report Posted April 7, 2006 I think we need a Datasheet repository on the Wiki... There are some on the portal (it might need updating, when I clean out my C:\Temp directory I'll upload them if I can) we could just link to those... Or maybe move those files to the Wiki? I don't know... I'll leave that to you webmaster types :) Anyway, I've now added various LCD PDFs to my temp directory for uploading later on, including the official Hitachi 44780 Datasheet.I must admit that, in the defense of the newbies, the information could be getting a little too spread out... There's ucapps.de, the forum, the wiki, the portal... Would it be worthwhile to attempt to bring some of that info together? Newbies, please let us know what you think... Maybe I am trying to make it too easy?
LiFo Posted April 7, 2006 Author Report Posted April 7, 2006 Mobius thanks for the verry positiv informativ anwser i was more looking for an anwser in the line of this >is there any command you can sent to the display to get it to blink>or is it only the cursur that is blinkin no there is no command to get the display to blink only the cursor >or have i to programm it my self to blink ?yes you have to but there is a command you can send to the display to hide (turn off) the text and another to show(turn on) the text again look at example furder down>if i have to make it blink my selv >i was thinking about using a timer somhow sounds like a good idea >i have only looked breafly at the function page and as i understand there are only 1 timer i can use >was also thinking to use another timer to make one dout blink a diode indicating the tempo >to get me started, some c examples using a timer would be realy great make 2 variables char blink;char blinkNr;in init methodevoid Init(void) __wparam{ blinkNr = 0; blink = 0; //initialize timer to fire each 50 ms MIOS_TIMER_Init(0x03,62500); }in the Timer function make this void Timer(void) __wparam{ if(blinkNr == 10) { blinkNr = 0; TogleBlink(); }else { blinkNr++; }}void TogleBlink(){ if(blink == 0) { // sends a display on command MIOS_LCD_Cmd(8+4); blink =1; }else { // sends a display off command MIOS_LCD_Cmd(8); blink = 0; }}this maby a stupid way of doing it but i dont know any better and nowbody seams to be villing to help a newbie so this is how i am going to do itand if another newbie like me wants to do the same think here is a simple solution
moebius Posted April 7, 2006 Report Posted April 7, 2006 Mobius thanks for the verry positiv informativ anwser Thank You - I'm always happy to not please.Let me ask You one question: Even with a detailed reply, Do You think you would accomplished this WITHOUT reading the datasheet and looking at the HD44780 command set?Good work - what, did it take a day without proper help from here ;)Moebius the Sunshine
stryd_one Posted April 7, 2006 Report Posted April 7, 2006 Clearly, I AM trying to make it too easy! Ignore my previous thoughts on centralisation please.Mobius thanks for the verry positiv informativ anwser Hey man, lets face it, he was being sarcastic, but he was right. You gave NO indication that you'd read it, so reading it was the next step.i was more looking for an anwser in the line of this That's bloody great!! If you'd posted that first, wow, I would have jumped to help you out! That really shows what some more investigation can do. Just the MIOS C function reference, the 44780 datasheet, and some C, and you have your answerSo well doneBut dude, what is this little temper tantrum all about?this maby a stupid way of doing it but i dont know any better and nowbody seams to be villing to help a newbie so this is how i am going to do itand if another newbie like me wants to do the same think here is a simple solutionReally, it's not like that, and I think you know that. We're both more than happy to tell you what you need, and we did. Once again, you have posted your thoughts and asking for confirmation that you've got it right and we are telling you yes. Why are you making out like you didn't get any help? Wasn't the datasheet enough? I went and opened and read it just then to check it out and make sure you had the right code, and there it is, page 25. Then it dawned on me... I will answer your questions with references to the datasheet, just to show you that when Mobius said to read the datasheet, he DID give you the answers you typed out... here they are:Google tells me:http://www.trash.net/~luethi/microchip/datasheets/lcd/hd44780.pdfis there any command you can sent to the display to get it to blinkor is it only the cursur that is blinkin Page 2Wide range of instruction functions:¾ Display clear, cursor home, display on/off, cursor on/off, display character blink, cursor shift,display shiftYou don't want the first one, cause you want the letters to come backYou don't want the 2nd oneThe third one you could use by turning it on and offThe fourth is only the cursorThe fifth is only the characterThe others are shifts, you don't want thoseSo obviously you want display on\off... hit search, type it in, clickety-click and page 25 comes up:Displayon/offcontrol0 0 0 0 0 0 1 D C B Sets entire display (D) on/off,cursor on/off ©, and blinking of cursor position character (B).37 ?sSo we ignore B and C, on and off are:0 0 0 0 0 0 1 0 0 0 = 80 0 0 0 0 0 1 1 0 0 = 12or have i to programm it my self to blink ?See above. to get me started, some c examples using a timer would be realy great http://www.ucapps.de/cmios_fun.html#MIOS_TIMER_Inithttp://www.ucapps.de/cmios_fun.html#USER_TimerThose links contain all the syntax for the commands. Obviously some creativity is required as to how you use them, but clearly you require no assistance there! If you'd have done everything else above, and had a go at the code based on those references, I'm sure moebius would have helped if it needed fixing.So why did I go to all this effort? Because I'm tired of people getting out the violins and having a sook when they don't get hand-held. Man, I didn't know this stuff off the top of my head, I had to go check them datasheets. Let me tell you, I've done very very little with LCD's in MIOS as yet, I haven't had the need to. It wasn't quick, I've been sitting here copying links for an hour or so - but the answers are RIGHT THERE.Now this part, I planned on answering when you came back after reading up a bit. Now I will, because you clearly have!if i have to make it blink my selv i was thinking about using a timer somhow i have only looked breafly at the function page and as i understand there are only 1 timer i can use was also thinking to use another timer to make one dout blink a diode indicating the tempo No problem :) The tempo will either be internally generated using or externally generated F8 bytes, interpolated by TK's algorithm (You'd be mad to write your own, it's great!) either way, it will be 96ppqn (pulses per quarter note).So you setup a pair of countdowns which will control the two flashes. Each time a F8 byte is received while you are playing, you decrement the counters by one. When they reach 0, you loop them back to their default.The tempo counter can blink every 1/4 note, so that counter default is 96. Leave the LED off, and when you hit play, turn it on, and start the countdown. When it reaches 84 you turn the LED off, so it pulses for a 1/32nd note for each quarter (or turn it off at 90 for a 64th note etc). When it reaches 0, you turn it on and reset the counter to 96...The screen will blink faster than that (crikey your timer is set to 50ms my gosh that's a fast blink, I would go slower than that. I think that's more like vibration ;) ) let's make it black out every 4th 16th note... That counter's default would be 24. You leave the screen on, and when you go into bllink mode you start the countdown. When it gets to 6, you turn the LCD off, when it gets to 0, you turn the LCD on and reset the counter to 24.These are just examples, have a play :)If you don't want to ues MIDI Clock command like above, you could just set a timer to 96ppqn@120BPM or something... Use your imagination, you very clearly have the skills required to do this customisation!Hope that helps.PS, you don't have to do fancy timed blinks like above, you can just set a timer that turns it off, counts down, turns it on, counts down, turns it off.....etc etc Faster, but not as pretty.
LiFo Posted April 7, 2006 Author Report Posted April 7, 2006 dont take this the wrong way i am happy with all the help i have got an can get i am lazy and have always been and this is a project i am doing for a frend so i am not so entusiastic and driven as many of you therfor am i seeking the shortcutsmobius to your question Let me ask You one question: Even with a detailed reply, Do You think you would accomplished this WITHOUT reading the datasheet and looking at the HD44780 command set?yes it would be sufficient to inform me that i have to do it my self and that i could turn off the text with 0x08and turn it on with 0x0cstryd_one(crikey your timer is set to 50ms my gosh that's a fast blink, I would go slower than that. I think that's more like vibration Wink )yes the timer is set for 50 ms but if you look at the ToggleBlink function you vil see that here is a counter so the real blink frequancy is ½ sec.sorry for my wage misleding question about the tempoyou gave a long detailed explanation about something else than the thing i wanted (i think ? or i hope so else it sounds way to complicated)i don't even know my self what i want i am making a floorboard for my friendand i only implement what he tells me and the hole proccess is extremly ad hocand among other things he wants a tap/tempo or something button on itto transmit some cc ommand (i think, have not researched)and if it is only a command to send out then the idea was to track internaly the tempo he is tapping the pedal and show the tempo on a diodebut hey not problen i have figured the timer out so there is no problem there ps. Spelling errors don't exist in my univers only coding errors
stryd_one Posted April 8, 2006 Report Posted April 8, 2006 dont take this the wrong way i am happy with all the help i have got an can get i am lazy and have always been and this is a project i am doing for a frend so i am not so entusiastic and driven as many of you therfor am i seeking the shortcutsGeez at least you're honest about it :) But you won't find many shortcuts around here, sorry mate. You might have gotten yourself in for more than you bargained for.... This stuff is going to be fairly indepth, and that's pretty much unavoidable.yes it would be sufficient to inform me that i have to do it my self and that i could turn off the text with 0x08and turn it on with 0x0cThis is my point - we don't go around memorising IC datasheets for fun, and we aren't amazing magical super-gurus who can recite hex codes for programming various devices off the tops of our heads.(Well I'm not, maybe TK hs the PIC18F datasheet committed to memory ;) heehhe) I had to read the datasheet just to see if you were right or not. See what I'm saying? To find out that is 8 and 12, one has to read the datasheet..... and I don't think that anyone here is going to help you so much as to go and read datasheets for you when you're perfectly capable of doing so yourself. To me it is like asking someone to read your homework for you. You were honest enough to admit that you're lazy, and I respect that a lot, so I will be honest enough to tell you that you're a bit too lazy if you expect such things of us ;) We're here to help, but not to be your eyes and ears, seeing eye dog or bedtime story readers ;) heheheheyes the timer is set for 50 ms but if you look at the ToggleBlink function you vil see that here is a counter so the real blink frequancy is ½ sec.Right you are. Sorry I missed that, I had been out all night, I even had a drink (yuck! I hate alcohol) it was 5 am, and I'd already spent an hour showing you that other stuff, I guess I overlooked it. I'm sure you understand :) My brain will come back soon hehehehsorry for my wage misleding question about the tempoyou gave a long detailed explanation about something else than the thing i wanted (i think ? or i hope so else it sounds way to complicated)i don't even know my self what i want i am making a floorboard for my friendand i only implement what he tells me and the hole proccess is extremly ad hocand among other things he wants a tap/tempo or something button on itto transmit some cc ommand (i think, have not researched)and if it is only a command to send out then the idea was to track internaly the tempo he is tapping the pedal and show the tempo on a diodebut hey not problen i have figured the timer out so there is no problem there ps. Spelling errors don't exist in my univers only coding errorsIf I were you I'd get my friend to sort it out. Making it up as you go along will make this even more confusing. Tell him to figure out what he wants, then give you the specs. Better yet, why can't he do it himself? If you're so unenthusiastic, and he is obviously too unenthusiastic, there's not a lot of enthusiasm going on there, and not much to drive the project. The project won't be incredibly hard, but it won't be a walk in the park either. With so little enthusiasm driving you both, you don't stand much of a chance :(What you're talking about is MIDI Clock and the thing I said that "sounds way too complicated" is just one little part of that... You'll need to write a tap-tempo function to set the clock period according to the speed of the taps.
