nikolaveselic Posted May 4, 2006 Report Share Posted May 4, 2006 I start making my first pic project (MIDIBox controller :-) ) It should be something like MIDIBox 64, but muy MIDIBox will have about 50 pots, and 30-40 Push-Buttons (I want to make controls for Native Instruments Traktor). Other moduls are not necessary?I made CORE modul (burner too) and LTC modul (because I don't have MIDI port). So can I program MIOS (second file mios_v1_9_pic18f452.hex which must be programed) over serial port or I must find other computer to put this file?Will I need something else of programing or moduls for this project?Sorry but my English isn't perfect :-)Thanx,Nikola Quote Link to comment Share on other sites More sharing options...
raphael Posted May 4, 2006 Report Share Posted May 4, 2006 I made CORE modul (burner too) and LTC modul (because I don't have MIDI port). So can I program MIOS (second file mios_v1_9_pic18f452.hex which must be programed) over serial port or I must find other computer to put this file?You have to burn the bootstrap-loader with the right ID for the LTC module. SmashTV has a ID calculator on his site: http://www.avishowtech.com/mbhp/idgen.html (0x0100 should be right for you if you use a normal LCD or no LCD).If you cannot select the ID in your programmer, you can change the ID directely in the hex file of the bootloader:Look for this line (near the end of the hex file)::080000000000000000000000F8Change it to this::080000000000000000000100F7[This is taken from a message by TK in the german forum: http://www.midibox.org/forum/index.php?topic=6051.msg37190#msg37190] Quote Link to comment Share on other sites More sharing options...
nikolaveselic Posted May 4, 2006 Author Report Share Posted May 4, 2006 thanxI had burned mios_update_v1_9\pic18f452\burner\bootloader_v1_2_pic18f452.hex without changes, but when I read your reply I erased my pic and burn him agen, but with changes. And when I put pic in core modul and connect core with LTC modul and with serial port and then open MIOSStudio beta4.4, I can't find MIDI IN and MIDI OUT on MIDI DEVICE ROUTING in the program.What I missed?nikola Quote Link to comment Share on other sites More sharing options...
johnh Posted May 4, 2006 Report Share Posted May 4, 2006 What I missed?Have you loaded a MIDI driver that talks to the serial port on the PC? Quote Link to comment Share on other sites More sharing options...
nikolaveselic Posted May 4, 2006 Author Report Share Posted May 4, 2006 no, I have KAWAI serial driver, but I don't know how to install him.can you help me?I know how on 98 1. Open the Control Panel 2. Choose the "Add New Hardware". Click "Next" to continue until you are asked to search the hardware. Then select "NO" and click "Next". 3. Choose "Sound, Video & Game Controllers" and click "Next". 4. Click "Have Disk". 5. Type the drive letter of the floppy disk or hard drive that has the driver in it, or browse to the folder with the driver in it. Then click "OK".But on XP?I have download it from http://www.kawai.co.jp/english/Download2.html#hnikola Quote Link to comment Share on other sites More sharing options...
nikolaveselic Posted May 4, 2006 Author Report Share Posted May 4, 2006 sorry for bothering :-) I have just install my kawai driver and upload mios_update_v1_9\pic18f452\midi\mios_v1_9_pic18f452.hex from MIOSStudio. LED on LTC module just stop blinking jeeeee :-)))so is that all, can I now open traktor to make setup or there's more programing to do?Thanx everyone for helping me!!!!!!Nikola Quote Link to comment Share on other sites More sharing options...
raphael Posted May 5, 2006 Report Share Posted May 5, 2006 can I now open traktor to make setup or there's more programing to do?You have to upload the application first (MIOS is only the operationg system). In your case this is the MB64 app:http://www.ucapps.de/mios/midibox64_v2_4.zipThe hole procedure is decribed here: http://www.ucapps.de/mios_bootstrap.htmlRaphael Quote Link to comment Share on other sites More sharing options...
