Hi everyone,
Just a question, how do you connect 2 parralel lcds with core module ? Do you solder 2 wires by pin on J15 when necessary or I don't know what is the more convenient.
Thanks for replies
Good midiboxing, Steph
Thanks for reply,
I see for the enable pin for the lcd, but to connect the data lines, Vs and all pins that are common to the 2 lcds, what do you use?
Steph
Yes, I will use J10/RC for the second enable line like the pdf example. I just wondered if someone design a pcb or something to extend J15 + 2nd enable pin in to 2*8 sockets to plug the 2 lcd with connectors.
Thanks for help.
Steph
