marcus77 Posted May 9, 2006 Posted May 9, 2006 Hi therei'm currently building a MBSid and am soldering together the first core module.Unfortunately I had to discover that the TrimmPot 10 k (Reichelt nr. PIHER 10-S 10K) have to big feet and don't fit in the predrilled holes.Just wanted to know if the following work fine as a replacement (part numbers at Reichelt.de):1.76-40 10K2.75H 10KThanks for the infomarcus
stryd_one Posted May 9, 2006 Posted May 9, 2006 Hi marcus, just about any 10K trimpot should do the trick :)
illogik Posted May 9, 2006 Posted May 9, 2006 hi;they are flat feet yeah?get a pair of pliers and fold the legs from this; | to this; C (top view ;))or use solder three cut pins of a resistor or something to the legs; doesn't look good, but works..
