GordTheRogue Posted May 28, 2006 Report Share Posted May 28, 2006 :) Hello to all,Finally i'm starting to build my MIDIbox SID Control Surface ver.I'm getting troubles on understanding the DIN soldering and wiring work.On DIN pagehttp://ucapps.de/mbhp_din.html we could read on 'Used Components' chapter that:These pull-up resistors are required if buttons are connected to the digital inputs.(talking about the 10k resistors).Does it mean i don't have to put resistors where i'll connect the encoders on DINx4 boards?Into the connection diagram http://ucapps.de/midibox_sid_cs/mbsid_din_default.pdf i couldn't see where resistors are and where aren't... instead of http://ucapps.de/midibox_sid_cs/mbsid_dout_default.pdf diagram which has resistors drawned.Again on http://ucapps.de/midibox_sid_cs/mbsid_din_default.pdf: the last board on right side is a DIN, does it have only one 74HC165 shift register? ???If so, what i have to do with the others three 74HC165s banks? (i have only DINx4 boards)I must put bridges or resistors(which?) between each last 3 shift registers' pinouts? ???Just a comment: on diagrams .pdfs couldn't be usefull a legend that clarify which symbols mean buttons, which mean encoders, etc.?? I hope to be understandable :-) Thanks all of you ppl out thereGord The Rogue Quote Link to comment Share on other sites More sharing options...
TK. Posted May 28, 2006 Report Share Posted May 28, 2006 Hi,the pull-up resistors are also required for rotary encoders. For the last DINX4 module, you don't need to stuff the unused 74HC165, so long R33 is connectedBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
GordTheRogue Posted May 28, 2006 Author Report Share Posted May 28, 2006 :D Thanks for the quick answer!!Talking about last DINx4, i understood to don't stuff 3 shift registers but: 1)Have I to stuff one shift register and near R1 to R8 resistors, included R33 right?2)What about others resistors (R9 to R32)? Do i have to stuff them? Also R34 to R36?Thank you again :-) Gord the Rogue Quote Link to comment Share on other sites More sharing options...
TK. Posted May 28, 2006 Report Share Posted May 28, 2006 To 1) yes, to 2) you don't need to stuff them for the "DINX1 functionality" (compare with the mbhp_dinx1 schematic)Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
