Digineural Posted June 12, 2006 Posted June 12, 2006 I'm having a little difficulty understanding the importance of some defines in the the MB64e applicationI understand that the following is setting shift registers 5-8 to be used for encoders 1-16.[pre]MIOS_ENC_PIN_TABLE ;; encoders 1-16 ;; SR Pin Mode ENC_ENTRY 5, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 1 ENC_ENTRY 5, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 2 ENC_ENTRY 5, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 3 ENC_ENTRY 5, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 4 ENC_ENTRY 6, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 5 ENC_ENTRY 6, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 6 ENC_ENTRY 6, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 7 ENC_ENTRY 6, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 8 ENC_ENTRY 7, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 9 ENC_ENTRY 7, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 10 ENC_ENTRY 7, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 11 ENC_ENTRY 7, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 12 ENC_ENTRY 8, 0, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 13 ENC_ENTRY 8, 2, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 14 ENC_ENTRY 8, 4, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 15 ENC_ENTRY 8, 6, MIOS_ENC_MODE_NON_DETENTED ; V-Pot 16[/pre]However I'm not quite sure what is being defined here[pre]#define DEFAULT_DIN_SR_PIN_01_08 2#define DEFAULT_DIN_SR_PIN_09_16 3#define DEFAULT_DIN_SR_PIN_17_24 1#define DEFAULT_DIN_SR_PIN_25_32 4#define DEFAULT_DIN_SR_PIN_33_40 8#define DEFAULT_DIN_SR_PIN_41_48 10#define DEFAULT_DIN_SR_PIN_49_56 11#define DEFAULT_DIN_SR_PIN_57_64 12[/pre]Should this defined before the encoders or can this be left out? Please AdviseDan
TK. Posted June 12, 2006 Posted June 12, 2006 Hi Dan,you will find my answer here: http://www.midibox.org/dokuwiki/doku.php?id=midibox64eBest Regards, Thorsten.
Digineural Posted June 16, 2006 Author Posted June 16, 2006 I'm having a wee bit of trouble with the encoders still. :-\ My current MB64e (really 16 encoders) is only semi functional as I was able to get only the menu bottons working on the first DINX4 board. Shift registers 2-4 have nothing connected yet. On the second DINX4, I have 16 encoders from SmashTV. I have tried various encoder defines and I cant get them to work at all. I double checked my boards and the voltages and connections are ok. My current setup is:[pre]MIOS_ENC_PIN_TABLE ;; encoders 1-16 ;; SR Pin Mode ENC_ENTRY 5, 0, MIOS_ENC_MODE_DETENTED2 ; V-Pot 1 ENC_ENTRY 5, 2, MIOS_ENC_MODE_DETENTED2 ; V-Pot 2 ENC_ENTRY 5, 4, MIOS_ENC_MODE_DETENTED2 ; V-Pot 3 ENC_ENTRY 5, 6, MIOS_ENC_MODE_DETENTED2 ; V-Pot 4 ENC_ENTRY 6, 0, MIOS_ENC_MODE_DETENTED2 ; V-Pot 5 ENC_ENTRY 6, 2, MIOS_ENC_MODE_DETENTED2 ; V-Pot 6 ENC_ENTRY 6, 4, MIOS_ENC_MODE_DETENTED2 ; V-Pot 7 ENC_ENTRY 6, 6, MIOS_ENC_MODE_DETENTED2 ; V-Pot 8 ENC_ENTRY 7, 0, MIOS_ENC_MODE_DETENTED2 ; V-Pot 9 ENC_ENTRY 7, 2, MIOS_ENC_MODE_DETENTED2 ; V-Pot 10 ENC_ENTRY 7, 4, MIOS_ENC_MODE_DETENTED2 ; V-Pot 11 ENC_ENTRY 7, 6, MIOS_ENC_MODE_DETENTED2 ; V-Pot 12 ENC_ENTRY 8, 0, MIOS_ENC_MODE_DETENTED2 ; V-Pot 13 ENC_ENTRY 8, 2, MIOS_ENC_MODE_DETENTED2 ; V-Pot 14 ENC_ENTRY 8, 4, MIOS_ENC_MODE_DETENTED2 ; V-Pot 15 ENC_ENTRY 8, 6, MIOS_ENC_MODE_DETENTED2 ; V-Pot 16[/pre]Is there something else that I need to do to get them to work?
TK. Posted June 16, 2006 Posted June 16, 2006 Just to be sure: did you already test the encoder and DINX4 module connections?Details can be found here: http://www.midibox.org/dokuwiki/doku.php?id=din_moduleBest Regards, Thorsten.
Digineural Posted June 16, 2006 Author Posted June 16, 2006 I'll take a stab at it when I get home from work. Thanks
