I'm interested in building a PG-300 clone for my Roland Alpha Juno 1. Can anyone here recommend a path for me? I'm new to this sort of DIY (but not electronics and DIY in general). If I understand everything correctly, the synthesis parameters on the Juno1 are controlled via sysex messages. Is MIDIBOX.ORG the right place for me? Or should I be barking up another tree? Thanks much.
SysEx messages can be sent with MIDIbox64 and MIDIbox64E by using "Meta Events", but this requires that you are doing (simple) enhancements in the application. An programming example for SysEx can be found in mb64_meta.inc/mb64e_meta.inc within the source code packages
In addition it makes sense to run the applications in patch mode, some infos can be found here http://www.midibox.org/dokuwiki/doku.php?id=midibox64_e_patchmode
