Shum Posted June 26, 2006 Report Posted June 26, 2006 Hi,My MIOS midibox64 is up and running, however as I am using a 2x24 LCD, the image presented is not at the center. How to make modification on the firmware to center the display. ThanksBest regardsShum
TK. Posted June 26, 2006 Report Posted June 26, 2006 Hi Shum,in main.asm, set:#define DEFAULT_LCD_SIZE 1 for 2x20 display mode, and replace #if DEFAULT_LCD_SIZE == 1 ; 2x20 #define DEFAULT_YOFFSET_LINE0 0x02 #define DEFAULT_YOFFSET_LINE1 0x42 #define DEFAULT_YOFFSET_LINE2 0x16 #define DEFAULT_YOFFSET_LINE3 0x56 #define CSMD_YOFFSET_LINE0 0x00 #define CSMD_YOFFSET_LINE1 0x40 #define CSMD_YOFFSET_LINE2 0x14 #define CSMD_YOFFSET_LINE3 0x54#endif[/code] by: [code]#if DEFAULT_LCD_SIZE == 1 ; 2x24 #define DEFAULT_YOFFSET_LINE0 0x04 #define DEFAULT_YOFFSET_LINE1 0x44 #define DEFAULT_YOFFSET_LINE2 0x18 #define DEFAULT_YOFFSET_LINE3 0x58 #define CSMD_YOFFSET_LINE0 0x02 #define CSMD_YOFFSET_LINE1 0x42 #define CSMD_YOFFSET_LINE2 0x16 #define CSMD_YOFFSET_LINE3 0x56#endifBest Regards, Thorsten.
Shum Posted June 27, 2006 Author Report Posted June 27, 2006 Hi Thorsten,I looked at the main.asm file in the midibox64 application and replaced the code as recommended (for 2x24 LCD). Using MPLAB, I recompiled the main.asm file to build the main.hex file. This was done successfully. I then uploaded this file through MIOSStudio into the pic. Mios rebooted, but the LCD display remains at 2x16 configuration. I searched through the readme file but could not find information on LCD setting. Could I be doing something incorrect here?. ThanksBest regardsShum
TK. Posted June 27, 2006 Report Posted June 27, 2006 Hi Shum,could it be that you forgot the first modification I mentioned (setting the display type)The information on LCD setting are in the main.asm file (the comments...). I know that some can be really confused, but nobody took the time for writing a user documentation into the Wiki yet...Best Regards, Thorsten.
Shum Posted June 28, 2006 Author Report Posted June 28, 2006 Hi ThorstenIt was carless of me that I missed changing the first line of the code. It is fine now, thanks a lot.Best regardsShum
stryd_one Posted June 28, 2006 Report Posted June 28, 2006 Hey Shum would you like to document this on the wiki? :)
Shum Posted June 29, 2006 Author Report Posted June 29, 2006 Hi Stryd_one,Yes, how do I go about doing it?RegardsShum
stryd_one Posted June 29, 2006 Report Posted June 29, 2006 Good on you mate ;)You can find the wiki syntax here: http://www.midibox.org/dokuwiki/doku.php?id=syntaxYou can fool around here and do whatever you want to test it out and get a feel for how it works: http://www.midibox.org/dokuwiki/doku.php?id=playgroundThen go here and share what you've found: http://www.midibox.org/dokuwiki/doku.php?id=midibox_64Let me know if you need a hand :)
Shum Posted June 30, 2006 Author Report Posted June 30, 2006 Hi Stryd_one,I had a look at the wiki syntax and the rest of the stuff at the playground, sorry I do not understand all the stuff there. Anyway I have done some work with MS Frontpage. Would it be possible to document what I have done on the LCD in Frontpage and upload it to the web? ThanksRegardsShum
stryd_one Posted June 30, 2006 Report Posted June 30, 2006 If you have a place you can host the files, or could send them to me, I can convert them to wiki format.
Shum Posted July 1, 2006 Author Report Posted July 1, 2006 Hi Stryd_One,I shall send you the document on my experience in building the midibox, once I finished it. Need your mail address. Thanks.Best regardsShum
stryd_one Posted July 5, 2006 Report Posted July 5, 2006 I just want to thank Shum for the really good documentation he's written. I'll be putting it online soon, but I wanted to say thanks now.
protofuse Posted March 19, 2010 Report Posted March 19, 2010 (edited) Hi Shum, in main.asm, set: #define DEFAULT_LCD_SIZE 1 for 2x20 display mode, and replace #if DEFAULT_LCD_SIZE == 1 ; 2x20 #define DEFAULT_YOFFSET_LINE0 0x02 #define DEFAULT_YOFFSET_LINE1 0x42 #define DEFAULT_YOFFSET_LINE2 0x16 #define DEFAULT_YOFFSET_LINE3 0x56 #define CSMD_YOFFSET_LINE0 0x00 #define CSMD_YOFFSET_LINE1 0x40 #define CSMD_YOFFSET_LINE2 0x14 #define CSMD_YOFFSET_LINE3 0x54 #endif by: #if DEFAULT_LCD_SIZE == 1 ; 2x24 #define DEFAULT_YOFFSET_LINE0 0x04 #define DEFAULT_YOFFSET_LINE1 0x44 #define DEFAULT_YOFFSET_LINE2 0x18 #define DEFAULT_YOFFSET_LINE3 0x58 #define CSMD_YOFFSET_LINE0 0x02 #define CSMD_YOFFSET_LINE1 0x42 #define CSMD_YOFFSET_LINE2 0x16 #define CSMD_YOFFSET_LINE3 0x56 #endif Best Regards, Thorsten. a very old post... but a new question. my protodeck is based on 2 MB64 and I'm using a 2x20 too. so, where must I put this #define DEFAULT_LCD_SIZE 1 I guess the 2nd part of the constant definition should be done in my main.h ...?! Edited March 19, 2010 by protofuse
