wonder Posted July 1, 2006 Posted July 1, 2006 I've bought this lcd displayit's hd61202 basedthe seller gave me a datasheet (see the attach)I'm not so good with electronics (and with english also....sob)Can someone explain me connections?thanks
stryd_one Posted July 1, 2006 Posted July 1, 2006 Hi wonder,If you are not so experienced then I would highly recommend using a display which is MIOS compatible. You may need to write a new driver for this device.Edit: No you won't have to write a new driver, that device is supported. I obviously didn't read the page well enough! I thought it was a CLCD ::)
wonder Posted July 1, 2006 Author Posted July 1, 2006 but, don't the chip hd61202 assure the compatibility?
fluke Posted July 3, 2006 Posted July 3, 2006 http://ucapps.de/mbhp_lcd.html has instructions for wiring a hd61202 based display
docbrown Posted July 3, 2006 Posted July 3, 2006 Can you be more specific to what is you are confused of? Is it about the diagram that you provided or the connection instruction from the LCD_Module page?
wonder Posted July 3, 2006 Author Posted July 3, 2006 i'm trying to match info from my diagram and info from connection instruction from the LCD_Module page.For example.....i suppose that the en signal in my diagram is the enable (marked as E http://www.ucapps.de/mbhp/mbhp_glcd0.pdf, I suppose), but what is D/I signal in my diagram? R/S? I don't know.....etcetc
