mess Posted July 4, 2006 Posted July 4, 2006 Hello,could someone explain to me the difference between MK_SET_OBJ and MK_ADD_OBJin makefile.spec used for generating the makefile?mostly I use something like this MK_SET_OBJ pic18f452.c main.c MK_ADD_OBJ myfile1.c myfile2.c wich does the trick but I'd like to now why :)bye,Michaël
TK. Posted July 5, 2006 Posted July 5, 2006 Hi,MK_SET_OBJ clears the object list and creates a new one. MK_ADD_OBJ adds objects to the current list.It's just a preparation for an unimplemented feature, which would allow to build multiple .hex files with different objects with a single "make" run.Best Regards, Thorsten.
mess Posted July 5, 2006 Author Posted July 5, 2006 ok I understand now,thank you very much for your time :)
