cimo Posted July 11, 2006 Posted July 11, 2006 hi alli want to map 7 buttons of a mb64e to change the channel of the MIDI data output, as to say button 1 = channel 1, button 2 = channel 2, etc.but i don t use menu buttons or lcd on my prject so i can t program the banks/groupsi have 12 encoders24 buttons16 potsany idea?thankssimone
TK. Posted July 12, 2006 Posted July 12, 2006 Hi Simone,you could create Meta Events in mb64e_meta.inc, which set the global MIDI channel, e.g.:MB64E_META_Handler_00 ;; set global channel to the second byte of a F0 xx meta event movff MB64E_GLOBAL_CHANNEL, MIDI_EVNT1 returnMeta Event F0 01 assigned to a button will set the channel to #1Meta Event F0 02 assigned to a button will set the channel to #2Meta Event F0 03 assigned to a button will set the channel to #3etc...F0 00 will disable the global channel feature (MIDI events are sent via the programmed channel)Best Regards, Thorsten.
cimo Posted July 13, 2006 Author Posted July 13, 2006 what about setting buttons to switch among different banks? can i program banks without lcd and menu buttons?btw i am also on the construction of a controller specifically built for ableton i will update picture and schematics soon (what soon means ...yeah.. you know that)regards simone
TK. Posted July 14, 2006 Posted July 14, 2006 what about setting buttons to switch among different banks? can i program banks without lcd and menu buttons?this is possible since ca. 4 years ;-)-> http://www.ucapps.de/midibox64e/midibox64e_sfb_table.txtBest Regards, Thorsten.
cimo Posted September 10, 2006 Author Posted September 10, 2006 hi allok so far i ve added that meta event 00 to mb64e_meta.inc as describedi have tried1 to create a .ini file with a few buttons assigned to F0 01 (02,03, etc) 7F (is this correct? i tried also 00) on/off (is this correct?)2 to use vmidibox to change the buttons as Meta Event with Meta ID = 1, byte 0 = 240, Nr. = 1 (2,3 etc), i tried all the different modesapparently the buttons send a syx so they have been configured but there is no channel change where is the bug?? thankssimone
TK. Posted September 14, 2006 Posted September 14, 2006 Did you build a new .hex file from your modified code, and uploaded it to your MIDIbox?Because it sounds like the default meta handler is still running - it sends SysExBest Regards, Thorsten.
cimo Posted September 15, 2006 Author Posted September 15, 2006 as usual and DUE .. thanks for the support yes i ve rebuilt the application and uploaded it i ve exchanged the default meta event 00 with the new one as described what about the byte1 is it supposed to be 00 or 7F ? best simone
TK. Posted September 15, 2006 Posted September 15, 2006 what about the byte1 is it supposed to be 00 or 7F ?You can assign any number to the second byte - sometimes this is useful for more flexible meta eventsBest Regards, Thorsten.
cimo Posted September 18, 2006 Author Posted September 18, 2006 oki ve made my way throught my new osx system and now i have all the needed tools to change/upload the applicationanyway i can t get my problem solvedi repeat the steps i took:1 upload a customised mb64e application2 swap the default MB64E_META_Handler_00 with the one you (Thorsten) posted i didn t change anything else3 re assemble main.asm and upload the application again4 download the mk_syx, modify the midibox64e.ini for my application5 convert to a syx file6 upload the new syxresultsin midi monitor i can see that now those buttons are sending a syx and not a note but no midi channel change!! i assume that somehow the meta handler is not activequestionsis it possible that when i upload the new midibox64e.syx file i am overwriting the meta handler? how will the midibox "listen" to the buttons sending the F0 00 (01 02 etc) event? is it an internal process?thanksbest regardssimone
TK. Posted September 18, 2006 Posted September 18, 2006 Whenever you are pressing a button which is assigned to a Fx event (Exception: FF), or when you are turning a pot which is assigned to a Fx event, the application will branch to the meta handler in mb64e_meta.inc - so, if you do see other MIDI events as expected, the problem must be inside the meta handler, and nowhere else.No, a midibox64e.syx file only overwrites the configuration data, it doesn't overwrite any codeBest Regards, Thorsten.
