Hi
I have been plugin in all the needed components for fully featured 4-sidmidibox sid at Reichelt (incl. pic burner).
http://www.reichelt.de/inhalt.html?SID=20%408kz8qwQARQAADlH8L805602a31561e64b09ba90fdc33027976;ACTION=48;LASTACTION=5;SORT=artikel.artnr;GRUPPE=P65;WG=0;SUCHE=CLIP%209V;ARTIKEL=CLIP%209V;END=16;STATIC=0;FC=667;PROVID=0;TITEL=0
Direct link to Warenkorb:
http://www.reichelt.de/inhalt.html?SID=20%408kz8qwQARQAADlH8L805602a31561e64b09ba90fdc33027976;ACTION=5;LASTACTION=4;SORT=user_artikel2.id;WG=0;SUCHE=1%2F4W%201%2C0k;START=0;END=16;STATIC=0;FC=666;PROVID=0;TITEL=0
Can you see the above links, or are they bound to cookies on my local machine?
There was 3 components i could not find. It was:
Resistor 1 kOhm   |   8 | 1/4W 1k   | 0.03 |   0.06 |
Polarised Capacitor 2200 uF/25V(!) | 4 | rad 2200/25   | 0.35 |   0.35 |
Polarised Capacitor 2200 uF   |   4 | rad 2200/16   | 0.26 |   0.26
Can i use other components instead of these 3? Would someoneplease check if reichelt has these components under some different name.
If anyone with a lot of time on there hand could just take a quick look on my link, to see if there is something very obvious wrong with it..... I can easily understand if no one will, im almost ashamed to ask.
Thank you
/Carsten
Resistor: "1/4W 1,0k"
2200 uF/25V cap: "rad 2.200/25"
2200 uF/16V cap: "rad 2.200/16"
seems that the search function of reichelt doesn't work so nice like months before... I will fix this in the order lists
