c0nsumer Posted August 16, 2006 Author Report Posted August 16, 2006 damn. looks sharp as hell. Nice workThank you. :)-Steve
Wild_Weasel Posted August 16, 2006 Report Posted August 16, 2006 gorgeous. Is that the M-Audio Keyboard with the drum triggers on the upper right side?I think this thing is also great fun.Cheersm.
c0nsumer Posted August 16, 2006 Author Report Posted August 16, 2006 gorgeous. Is that the M-Audio Keyboard with the drum triggers on the upper right side?I think this thing is also great fun.Thanks. And no, it's just a cheap Radium 49... Both side and knob-type pots to send various MIDI bits. I don't have them set up to send anything yet, though. I'm more concerned with getting the MIDIbox SID-NUXX going first.-Steve
rogic Posted August 16, 2006 Report Posted August 16, 2006 It looks better than some commercial products I've seen :ogreat job, Steve
c0nsumer Posted August 16, 2006 Author Report Posted August 16, 2006 It looks better than some commercial products I've seen :ogreat job, SteveThanks. It was designed that way. The final one (with that faceplate) will have slightly dimmer LEDs. The resistors in place with those are intended to be used with some diffuse red LEDs which are a bit darker.Also, due to my misunderstanding the switches (although I thought I triple-checked it), the current front panel PCB isn't right. That has to be fixed as well.However, things are seeming to work out exactly how I intended it. That is, I end up with some MIDIbox SID's and everyone else gets enough plans / details that they can easily duplicate the work.-Steve
docbrown Posted August 16, 2006 Report Posted August 16, 2006 it's just a cheap Radium 49... Dude,You got that right!! The Radium looks very cheap, compare to your SID-NUXX!! ;D M-Audio should consult you regarding visual/color scheme design!! Coz, that SID is sweet look'n. ;)l8r..
