moxi Posted July 31, 2006 Posted July 31, 2006 hi,i've read that for the first implementation of the driver for aout-lc module in the sid app, only the resonance can be outputed to aout, i'm right?does that mean that only one aout-LC module is supported by this app?
stryd_one Posted July 31, 2006 Posted July 31, 2006 I thought it was 16bit broken down into 4 bits for resonance and 12 bits for cutoff?
moxi Posted July 31, 2006 Author Posted July 31, 2006 ok, after some test, i've seen that my first cv drive the cutoff and the second drive the rezo, it's perfect..but now , are the second aout-lc supported by the apps? if yes , wich parameter are routed to the cv?what i want :to get the lfo to modulate my third cv , and the env to modulate my fourth cv...
moxi Posted July 31, 2006 Author Posted July 31, 2006 more test:it's appear that the cutoff modulate my CVs 1 and 3, and the rezo modulate CVs 2 and four! ???
TK. Posted July 31, 2006 Posted July 31, 2006 A second AOUT_LC module is not supported, this is documented in the ChangeLog (which you've translated ;-).Therefore you will see the previous values of the first two outputs at the second two outputs againBest Regards, Thorsten.
moxi Posted July 31, 2006 Author Posted July 31, 2006 thanks...my translation was probably not enough clear!!! :P
