hi,
i've read that for the first implementation of the driver for aout-lc module in the sid app, only the resonance can be outputed to aout, i'm right?
does that mean that only one aout-LC module is supported  by this app?
ok, after some test, i've seen that my first cv drive the cutoff and the second drive the rezo, it's perfect..
but now , are the second aout-lc supported by the apps? if yes , wich parameter are routed to the cv?
what i want :to get the lfo to modulate my third cv , and the env to modulate my fourth cv...
A second AOUT_LC module is not supported, this is documented in the ChangeLog (which you've translated ;-).
Therefore you will see the previous values of the first two outputs at the second two outputs again
