audiocommander Posted August 7, 2006 Posted August 7, 2006 Hello everyone,in my need for an application that can easily send NRPN or SysEx messages to debug my application (unfortunately that's not yet implemented in MIOSStudio and I'm always beginning to cry somewhen if I have to use MIDIpipe), I just stumbled upon a most incredible and absolutely stunning piece of software: miniAudicle is a realtime audio programming software, based on the open-source Chuck-Realtime-Audio-Programming Language, developed at Princeton....jeez, think about that: realtime means, you can program LIVE! ;D 8)for example, this script opens a Midi-Out port and sends a PRG-CH Message: // create midi obj MidiOut mout; mout.open(0); // send some data MidiMsg msg; 192 => msg.data1; 0 => msg.data2; mout.send(msg); of course there are also events attachable, that react on incoming data, one can easily setup GUI elements like sliders and knobs and and and...get it here: (for Mac/Linux/Win)http://audicle.cs.princeton.edu/mini/cheers,Michael :D
TK. Posted August 7, 2006 Posted August 7, 2006 I normaly use the SysEx window of MIDI-Ox to send something directly.For example, type: 90 30 7Fand it will send a notetype:90 30 7F 31 7Fand it will send two notes (running status taking into account)The same can be done for NRPN:B0 62 01 63 02 26 03 06 0401 = NRPN LSB02 = NRPN MSB03 = data LSB04 = data MSBthere is no GUI of course, but you can save/restore such test streams as .syx file, which is nice for debugging suitesBest Regards, Thorsten.
audiocommander Posted August 7, 2006 Author Posted August 7, 2006 ( <hüstel*>... I'm on a mac ;) )...and although I do have a PC (with midiOX of course), I usually turn it on only if I have to use MBHP-Burner and can't avoid it ::)...but besides that, miniAudicle really seems to be a quite powerful tool with a lot more possible use than just sending some values (which is like scratching on the surface).I can absolutely recommend to give this one a try, I'm really enthusiastic about this piece of software :) especially if anyone is doing midi stuff and is used to programming (C or some other language like JavaScript)!Cheers,Michael
stryd_one Posted August 8, 2006 Posted August 8, 2006 Yeh those livecoder dudes are kinda berzerk ;DIf you're into it, check these out, a couple of my favourites.... http://www.pawfal.org/ (a terrible website, but give it some time and surf around, very interesting - if you only look at one page, check this one: http://www.pawfal.org/index.php?page=PawfalProjects) and http://www.nongnu.org/om-synth/ OM is very cool, as is TiSM http://tism.sourceforge.net/screenshots.html
audiocommander Posted August 8, 2006 Author Posted August 8, 2006 that's a bunch of cool links!thanks mate :D
