Modul Posted August 21, 2006 Report Posted August 21, 2006 Let me describe. We need a harware source of midi clock signal with 5 midi outputs. Here is the picture. So you see that this device isn't too difficult. Simple it should give a midi clock signal to 5 outputs. Start/Stop button.. Indicator.. And a knob to regulate tempo of the clock. So we hope that you or somebody can help us. Maybe someone can build this and we buy it...Midi Clock.JPG Quote
Modul Posted August 21, 2006 Author Report Posted August 21, 2006 Or maybe somebody knows a kind of existing device like that with not less than 3 outputs? Quote
stryd_one Posted August 22, 2006 Report Posted August 22, 2006 See those two links up the top that say uCapps and Dokuwiki? Click them! Keep clicking until you find your answer :) Quote
bill Posted August 22, 2006 Report Posted August 22, 2006 http://www.midibox.org/forum/index.php?topic=5691.msg34981#msg34981 :-* Quote
OrganGrinder Posted August 22, 2006 Report Posted August 22, 2006 for the multiple duplicate midi out, why not modify the LTC module.my idea was to take out ic1 and ic2, and then repeat the ic3 section as much as required (should also take out any unneeded midi thru aswell). there would be a limit on how far this can be done, but i don't have the expertise to say how far. but for 4 additional midi out (plus the 1 on the core), i wouldn't think there is a problem.and for such a simple circuit, it can easily be done on a stripboard.alternatively to provide 5 midiout, you could use 4 IIC Midi Modules plus the midi out on your core. it is a little more complex, but it would give the ability to independently adapt each midi out signal or just send the same midi out to each IIC module.OrganGrinder Quote
bill Posted August 22, 2006 Report Posted August 22, 2006 The clockbox got a new "multi MIDI Out option" based on an idea of Braintu.It allows to enable/disable the MIDI clocks of up to 8 MIDI clock slaves (sequencers, drum machines, synths) seperately and in a synchronized manner (clock will be enabled/disabled exactly on the next beat) Quote
stryd_one Posted August 22, 2006 Report Posted August 22, 2006 Yeh, check out the ultra simple wiring and bit banged midi. So cool. TK strikes again :) Quote
Modul Posted August 22, 2006 Author Report Posted August 22, 2006 Thanks guys! But how can i process a midi clock signal? Quote
Modul Posted August 22, 2006 Author Report Posted August 22, 2006 Oh and thanks for the link.. but i really suck in building such devices.. :'( Quote
