Programming two cores while linked
Hello,
since I didn't manage to program two cores in a MIDI Link
(ID 0 and 1, one forwarding point, one endpoint) while they
are linked, I disconnected them, set them to "enabled" mode,
replaced the application, and at the end activated the linked
mode using mk_syx, then reconnected.
Do you think there is a way to program them while they
are linked? This would avoid to open the device each time.
Thank you.
Ralf
Hi Ralf,
with MIOS Studio you can execute MIOS functions - which means, it is possible to enable the normal MIDI merger mode by calling MIOS_MIDI_MergerSet(1) from the debug window. You have to do this for both cores (device ID 00 and 01)
Btw.: the problem with the flickering LED matrix when debouncing is enabled is fixed now (-> MIOS V1.9c) :)
