i've built a Pic-Burner. All tests except SCLK on/off are passed fine. But when switching SCLK on or off nothing happens - always 5v on RB6. For testing i've exchanged the 74hc14, same results.
Any ideas whats going wrong?
Mike
I don't have any specific information about the PIC Burner module, but looking at the schematic I would want to know if pin 1 and 6 of the 74hc14 shows a clock signal.
Oh man, why didn't I came to this idea by myself. Doh!
But the results, hmm. 1,62 volts independend of the SCLK switch. Don't know what this means. Bad Parallel-Port?
(measured with plugged-in burner, without power-supply. had let recognise the burner by p18 and turned the power of after that)
I'm using the recommended cable from Reichelt.
Mike
I've found the error! It was the Parallel-Port, really disturbing that only the SCLK-Signal doesn't work. But ok, with another PC it works as desired.
Thanks to you all for your help!
Mike
