havensole Posted September 21, 2006 Posted September 21, 2006 Hi all, sorry for my ignorance, but i've checked around and can't find anything that really helps. I am trying to do my own design for the front panel of my SID and am having some issues figuring out how to add minor features and take away others, as well as figuring out how to fully edit encoder features. I am attaching the rough design for the frontpanel (mind you the picture is split so it'll fit on a standard sheet of paper). The vertical boxes are for the encoders, the larger circles are the LED's, and the smaller ones are the buttons. The main issue I need help with are the redifining of the OSC encoder section, the addition of a second LFO section, and the different options in the ENV section. Thanks in advance for your help guys. If I am asking too much, please just point me to where I can learn how to tweek these things.
havensole Posted September 21, 2006 Author Posted September 21, 2006 ok, i think i need to simplify. my big issue is understanding how MIOS can tell when say, "ENC_ENTRY 3, 2, MIOS_ENC_MODE_DETENTED2 (code from the MIOS_TABLES.INC) is routed to "Osc attack/finetune/assign #2." i've been looking in the other files and can't seem to find something that defines the encoder input #2 going to a specific function, unless i am just missing something in front of my face. lastly, can someone please help explain the following code in idiot speak for me. "CS_MENU_BUTTON_Osc_Ctrl ;; do nothing if button has been depressed IFSET MIOS_PARAMETER2, 0, return ;; increment OSC Ctrl parameter (0x00-0x02) incf CS_MENU_SELECTED_OSC_CTRL, F movlw 0x02+1 IFGEQ CS_MENU_SELECTED_OSC_CTRL, ACCESS, clrf CS_MENU_SELECTED_OSC_CTRL movlw CS_MENU_OSC ; change to OSC menu rcall CS_MENU_BUTTON_Hlp_MenuChange ;; set page offset and cursor pos depending on selected layer movf CS_MENU_SELECTED_OSC_CTRL, W bnz CS_MENU_BUTTON_Osc_Ctrl_Not0CS_MENU_BUTTON_Osc_Ctrl_0 movlw 0x03 rgoto CS_MENU_BUTTON_Osc_Ctrl_ContCS_MENU_BUTTON_Osc_Ctrl_Not0 IFSET CS_MENU_SELECTED_OSC_CTRL, 1, rgoto CS_MENU_BUTTON_Osc_Ctrl_Not1CS_MENU_BUTTON_Osc_Ctrl_1 movlw 0x09 rgoto CS_MENU_BUTTON_Osc_Ctrl_ContCS_MENU_BUTTON_Osc_Ctrl_Not1 movlw 0x00CS_MENU_BUTTON_Osc_Ctrl_Cont movwf CS_MENU_PAGE_OFFSET movwf CS_MENU_CURSOR_POS bsf CS_STAT, CS_STAT_MODIFY_PARAMETER goto CS_MENU_EXEC_Hlp_ChangeMenu ; deselect parameter"i can understand some of it, just not everything completely. thanks again in advance.-HS
Ixox Posted September 21, 2006 Posted September 21, 2006 Sorry but it's hard to understand what you want....That may be why you have no answer.I modifed some encoder functions and have explaind some code modification in :http://www.midibox.org/forum/index.php?topic=7233.0Read the last post...The main issue I need help with are the redifining of the OSC encoder section, the addition of a second LFO section, and the different options in the ENV section.For each could you explain the difference between what you'd like to have and the reference design ?Xavier
havensole Posted September 21, 2006 Author Posted September 21, 2006 ok, the OSC section, instead of having the OSC env, misc, and assign layers, it will only have a traditional octave (pitchrange i assume), pitch (transpose i assume), pulse width, and fine tune. originally i wanted a mix (level adjustment) for each OSC, but i don't see that anywhere in the code. next thing is the ENV CTRL buttons where i will be adding another layer. a misc. layer (that at the moment will only be able to control arp rate and port rate).lastly is the LFO section where i'd like to split the 6 LFO's into 2 parts. having 2 control sections, 1 which controls LFO's 1,3,and 5, the other controls LFO's 2,4, and 6. the code i posted before was from the "cs_menu_buttons.inc" file. and dealt with the code for osc ctrl function. the reason i asked for some explanation was that i was planning on getting rid of it, but it would explaain how to re-do the env ctrl section. sorry for all the confusion.-HS
Ixox Posted September 21, 2006 Posted September 21, 2006 ok, i think i need to simplify. my big issue is understanding how MIOS can tell when say, "ENC_ENTRY 3, 2, MIOS_ENC_MODE_DETENTED2 (code from the MIOS_TABLES.INC) is routed to "Osc attack/finetune/assign #2." i've been looking in the other files and can't seem to find something that defines the encoder input #2 going to a specific function, unless i am just missing something in front of my face. It took me some time to understand the encoder/function link.But i think what you are looking for is in cs_menu_enc.inc and the function is called CS_MENU_ENC_CS_Handler.The information it gets is the encoder line number in the mios_tables.inc or something like that.Hope that helps... At least that allow me modify some encoder behaviour.Xavier
